Thread: Property controls for individual segments of a POLYLINE ie layer, linetype, colour, line width.
    Wish List Administration
    2011-08
    4,581
    Default Property controls for individual segments of a POLYLINE ie layer, linetype, colour, line width.
    Summary: Polyline segment individual properties
    Description: The ability to have property controls for individual segments of a POLYLINE (between vertexes) ie layer, linetype, colour, line width etc.
    Product & Feature: AutoCAD
    Submitted: Mon, 21 Nov 2011
    2011-09
    Default Re: Property controls for individual segments of a POLYLINE ie layer, linetype, colour, line width.
    Plus the ability to control the polyline in the same way a line is controlled
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,665
    A lwpolyline is a single object Lineweight, Elevation, Plot Style and the properties you described apply to the entire object. Otherwize a group of contours with thousands of segments would increase a thousand times in size if each segment had individual properties. Why not explode the polyline and group it afterwards? Then you could toggle Groups off/on with Ctrl+H and modify each segment to your hearts content.
    2015-12
    2,095
    They *might* be able to get clever and assign lists of values for each property to the LWPOLY entity (e.g. linetype property as "BYLAYER;DASHED;DOT", color as "BYLAYER;RED;YELLOW"), with each segment using a list index to refer back to the specific property. Still, as mentioned with a large number of different properties those "light" PLINE won't be.
  1. Polyline issue with global width... vertex between line and arc
    By david.musrie346034 in forum AutoCAD LT - General
    Last Post: 2012-12-11, 10:36 PM
  2. Replies: 0
    Last Post: 2011-11-16, 09:09 PM
  3. break into individual segments
    By dotrvt in forum AutoCAD General
    Last Post: 2011-09-19, 01:36 AM
  4. Converting line segments into polyline
    By VBOYAJI in forum AutoCAD Map 3D - General
    Last Post: 2007-06-25, 01:56 PM
  5. Individual leader controls
    By Jshaver in forum Revit Structure - Wish List
    Last Post: 2007-02-22, 05:46 PM
