I have a metric landxml file (I'm in Canada and work in metric) and have several issues:
1. Looking at the database under the survey tab, the Northing and Easting appears to be proper for metric yet the elevation is converted to imperial (0.304.
2. When inserting the survey database into a drawing it "converts" the coordinates by 0.3048. It appears that somewhere along the line it thinks the coordinates are imperial and then converts them to metric.
3. Conversely, you load points straight into a drawing (from landxml or a point file) and put them into the survey database and it will convert by 0.3048.
We are using the C3D 2012 Metric install for drawings and confirm that units are metric for the drawings.
I'm not sure how else to explain this.
