Results 1 to 10 of 11
Thread: Door and Window Schedule - Worksets?
    I could stop if I wanted to funkman's Avatar
    2003-10
    Sydney, Australia
    437
    Default Door and Window Schedule - Worksets?
    We won in court against Council, hooray....and now we are in the process of CD's. I have previously modelled the neighbours windows and doors, and now when I come to schedule the doors/windows in our project, of course the neighbours items are displaying in the schedules.
    This would otherwise be ok, because I would normally schedule the new works only, BUT, it is alterations/additions and there are existing retained windows/doors to be displayed in the schedule.
    I have enabled worksets, and cannot see whether the schedule can be set to not display the 'neighbours' worksets? Or how would I schedule the project such that only this projects windows/doors from all phases are shown, but not the neighbours. I dont particularly want to delete the neighbours things just in case...
    2001-12
    Irvine, CA
    7,567
    Default Re: Door and Window Schedule - Worksets?
    Ignoring worksets, one way...add a shared parameter to doors like:
    Parameter name:schedule
    Data Type: yes/no
    Add yes/no to each door.
    Then filter the schedule to either include YES or exclude NO data.
    2003-10
    Sydney, Australia
    437
    brilliant - thanks a bunch Steve!
    On a side note - does anyone know whether worksets be enabled in schedules to filter out unwanted information?
    2002-09
    Sydney, Australia
    165
    AFAIK...Worksets can be used to control visibility of a 'set of elements' irrespective of their catagory and 'Phase' can be used to filter the items in a schedule. What Steve has suggested is another brilliant method to acheive the result.
    2003-05
    5,153
    Xavier is correct, worksets cannot be used as a filter field for schedules.
    All AUGI, all the time archjake's Avatar
    2003-07
    Tucson, AZ
    531
    Wouldn't the neighbors doors and windows be in phase 1, or an existing phase? Just set up a phase filter to show new only and filter your schedule by show new only...
    Revit Family Guy adegnan's Avatar
    2003-04
    DeForest, WI
    633
    I'd typically use Jake's solution.
    I like all the others too.
    Phases can filter most anything. But if you need multiple levels of filtering then you need to use one of the other solutions.
    2002-02
    St. Louis, MO
    4,695
    Workset filtering would be a great addition. It would really help us with estimating and a host of other issues...
    2004-08
    NYC
    13
    couldn't you just use one of the filters in the schedule...As in 'Filter By' 'Mark' 'is less than' 100 (where the windows marks for the neighbors bldg are 100+ ) opr something similar like that? That's how I would do it... but I'm sure there are at least 10 ways of doing it.
    Happy Friday.
    -Mike
    2003-10
    Sydney, Australia
    437
    thanks for all the replies....Steve's first suggestion worked great.
    Jake, couldnt use your idea since there are existing windows that are being retained and fixed up.
    Mike your idea was good as well but I already completed the task. Revit is too quick.
    I still like the idea of filtering with worksets though.
  1. Door and Window Assembly in a schedule
    By tra1133 in forum ACA General
    Last Post: 2009-05-06, 01:42 PM
  2. Door Window Size Schedule
    By tomdillenbeck in forum ACA General
    Last Post: 2008-07-26, 03:09 AM
  3. ACA2008 Door and Window Schedule
    By Marv Muston in forum ACA General
    Last Post: 2008-07-22, 04:57 PM
  4. Door and Window Schedule
    By Jun Austria in forum Revit Architecture - General
    Last Post: 2008-05-15, 12:01 PM
  5. Graphic Door and Window Schedule
    By bpayne in forum Revit Architecture - General
    Last Post: 2006-03-10, 05:04 PM
