Thread: Duct Lining
    2009-02
    26
    Default Duct Lining
    I just noticed with Revit 2012 when i hide an "element" in view it does not hide the duct lining associated with that item. The same issue occurs with Duct insulation but we typically do not print with duct insulation on so this isn't usually an issue. Since i am only lining 10-15 feet after mechanical equipment (Vav boxes for example) when i try to hide the elements it just appears as the floor plan is incomplete and missing information since the lining remains visible.
    The reason i was hiding elements in the view was to create a part plan. The standard in is to only show the elements within the part plan with tags/notes, etc. Is my only option to not hide the elements in the full view and only have tags within the part plans? or does anyone know a possible work-around?
    2005-08
    11,000 feet atop a chute
    1,001
    Default Re: Duct Lining
    This is a known issue and Adesk is working on it.
    A work around would be to remove the insulation and than re-apply.
    2011-08
    I have a similar problem, when I hide a duct that will be shown on another plan, the insulation stays on the page.
    I tried removing the insulation and re-applying it, but no luck. Was I supposed to do this in "Reveal Hidden Elements" mode?
    Thanks in advance.
  1. 2014: Showing Duct lining
    By madeel495827 in forum Revit - Platform
    Last Post: 2014-03-18, 04:37 AM
  2. Duct Lining Visibility
    By fduraes in forum Revit MEP - General
    Last Post: 2014-03-12, 08:28 AM
  3. Duct Insulation and Lining Tag
    By RPOY in forum Revit MEP - General
    Last Post: 2011-04-27, 03:11 PM
  4. Duct Insulation and Lining
    By JoelLondenberg in forum Revit MEP - Tips & Tricks
    Last Post: 2011-01-25, 07:56 PM
  5. DUCT LINING
    By thomasel98 in forum Revit MEP - General
    Last Post: 2010-08-24, 04:47 PM
