Thread: Shafts
    2011-11
    Default Shafts
    I have a new shaft placed in my model that is showing up in my demo plans. I am unable to select it in the demo views, but I can in the New Construction views. It has the appropriate filter and phase labeled for New Construction. How can I get the shaft to stop showing up in my demo plans? Thanks.
    2009-12
    Albuquerque, NM
    167
    Default Re: Shafts
    Welcome to the forums!
    Not sure without looking at your file, but it sounds like you are experiencing a standard Revit behavior. In order to place a shaft through existing floors, part of those floors needs to be demolished. Similar behavior happens when you add a new door into an existing wall.
    Hope this helps,
    -Logan
    I could stop if I wanted to Limbatus's Avatar
    2010-04
    Gamehendge
    281
    Default Re: Shafts
    need to add some floor area inside a shaft. i am finding that revit is automatically cutting all floor slabs in my shaft. is there a way to specify elements that do not get cut. i tried uncut geometry, but it wont allow me to select the shaft opening? any other solutions?
    2009-12
    Albuquerque, NM
    167
    Question Re: Shafts
    So you have a shaft with parts of floors sticking into it? In that case don't use the shaft tool at all. Just set up some reference planes as guides and modify the floor boundary lines on each level.
    The shaft tool is really more intended for a series of penetrations through multiple levels such as stairwells and elevators. For simplicity's sake I wouldn't use a shaft element on a building 3 stories or less imho.
    -LP
  1. New Shafts in Existing Building
    By phyllisr in forum Revit Architecture - General
    Last Post: 2015-11-06, 01:09 PM
  2. selecting shafts
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2010-08-02, 02:47 PM
  3. Foundation Slabs and Shafts
    By Mark.vB in forum Revit Structure - General
    Last Post: 2007-04-17, 04:53 PM
  4. Phasing Openings and Shafts
    By mmodernc in forum Revit Architecture - General
    Last Post: 2006-05-16, 11:33 PM
  5. Text in shafts
    By E-Key in forum Revit Architecture - Wish List
    Last Post: 2006-01-25, 04:51 PM
