Thread: How do I show skewed column grid in elevations?
    2002-07
    Douglasville, GA
    29
    Default How do I show skewed column grid in elevations?
    I have a floor plan where some of the column lines are not parallel with the others. In my elevation views these skewed grids do not show since they are not orthogonal to the view. So, the question is how do I show the missing column grid in my elevations?
    Allen
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    Default Re: How do I show skewed column grid in elevations?
    Quote Originally Posted by allen.hart View Post
    Allen
    You have to manually place a drafting line and draft a grid head bubble in the elevation view wherever you want the grid line to appear. Any adjustment will need to be handled manually.
    Technically there is no "right" position for the gridline to appear since it is not perpendicular to the view direction. Consequently Revit does not display them.
    ______________________________________________
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    2004-06
    Memphis TN area
    7,046
    The issue is where do you WANT the grid to be displayed in the elevation? Where the skewed grid intersects the outside face of the wall? At the nearest grid intersection? You can place a ref plane that is perpendicular to the elevation, and then align/lock a drafting line or a 2-pick detail component to that ref plane.
    AERC, PLLC
    Hernando, Mississippi
    2002-07
    Douglasville, GA
    29
    Thanks Jeff, that's what I'm thinking too. Was hoping I was missing something.
    Allen
  1. Grid Lines Not Visible In Elevations
    By Alan aka cadalot in forum Revit Structure - General
    Last Post: 2009-06-23, 09:06 PM
  2. Column Grids--no show in elevations
    By cliff collins in forum Revit Architecture - General
    Last Post: 2008-10-13, 10:12 AM
  3. Graphical Column Schedule and slab/column intersection not show correct in GCS
    By jonas.152865 in forum Revit Structure - General
    Last Post: 2008-07-16, 06:58 AM
  4. Column Grid Lines and Shifting Column Grids
    By .chad in forum ACA General
    Last Post: 2007-11-02, 03:42 PM
  5. Replies: 1
    Last Post: 2006-09-15, 03:18 PM
