Thread: Concentric Circles
    2008-07
    Washington DC
    82
    Default Concentric Circles
    I have a block that has 3 concentric circles. I need to be able to scale the outermost circle at 3/4" intervals (that part is easy). But I also need the middle circle to offset copies at 3/4" as the outer circle scales.
    I could do it with visibility states, but that seems counter productive since I need the outer circle to scale from 2 1/2" to 96". Is there a way to achieve this with dynamic properties?
    2009-01
    B5
    544
    Default Re: Concentric Circles
    Do you need the Middle circle to remain 3/4" form the Outer Circle or for there to be one, then two, then three, then four, then... circles when done?
    And what is the Radius of the minimal Outer circle?
    And Innermost circle?
    2008-07
    Washington DC
    82
    Quote Originally Posted by clshade View Post
    I need multiple mid circles when done, all circles maintaining a 3/4" spacing (see attached).
    Outer circle min radius = 2 1/2"
    2009-01
    B5
    544
    Drawing a goose egg here without using Vis States.
    There is no Offset Action which is what you would need.
    2008-07
    Washington DC
    82
    Yeah, that's where I was at. Just hoping there was another way to do this. Because I need the outer circle to vary between 2 1/2" and 96" I didn't want to use a visibility state. Thanks.
  1. 2015: Pipe Fittings - only concentric?
    By wolfgang.kopp594485 in forum Revit MEP - Families
    Last Post: 2015-02-06, 02:19 PM
  2. Dimensioning concentric arcs
    Last Post: 2010-10-06, 01:07 PM
  3. Problem with concentric circles and dynamic blocks
    By smudge in forum Dynamic Blocks - Technical
    Last Post: 2010-09-27, 09:06 PM
  4. Miscellaneous - concentric circles
    By Chris.N in forum Dynamic Blocks - Sharing
    Last Post: 2007-04-23, 07:57 PM
  5. I.D. Must be concentric to O.D. within .020 FIM - What does FIM stand for?
    By joeswantek in forum CAD Management - General
    Last Post: 2007-03-13, 08:32 PM
