Results 1 to 7 of 7
Thread: Curved UV grid?
    2009-03
    Somerville, MA
    669
    Default Curved UV grid?
    Is it possible to get a UV grid to do something like the attached? We have a project in which this happens quite a bit. The competition was done in Rhino but now that we have the project, there is a chance we'll do it in Revit. I'd love to try to use the Conceptual Massing tools for the shell of the building, but only if I can get this to work.
    2003-08
    Vancouver, BC Canada
    3,392
    Default Re: Curved UV grid?
    Turn off your U and V grids and divide the surface using 'intersects'.
    Check the help file for info.
    Basically you draw what you want to see in elevation and project the lines onto the mass surface.
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    2009-03
    Somerville, MA
    669
    I know how to do that, for sure, and that would be one way. However, I'd have to figure out the spacing manually and if I wanted the curved-surface to flex, I'd have to either move the curves manually or set up some parameters.
    I'm looking for the isocurves of the surface, which is a basic mathematical construct of UV-grid surfaces. Any thoughts?
    2003-08
    3,392
    The only way Revit will do that automatically is if the surface is out of plumb. As soon as you 'warp' the plane, it divides this way.
    As you suggest the math is pretty simple on this so the only approach I could see is to create a 'spline through points', copy that vertically so you have the number of divisions (control points ) you want for dividing the surface and then drive those points with an adaptive component placed vertically at the intersections. Simple division of the overall height should get you what you're after.
    BIMblog.ca
    2009-03
    Somerville, MA
    669
    Thanks, Dimitri. I'll give it a try. Since Revit does what I want on a "warped" surface as you say, it would be nice if you could choose to follow the isocurves of the surface or just divide it orthogonally.
    2012-04
    6
    I am trying to use a curved and sloping surface to create a curtain wall to be used as a continuous sunscreen. The idea is that he horizontal mullions can be trubular to form the sunscreen. However, the mullions don't follow the curvature of the curtain wall, but form a straight line from end to end. Any thoughts on fixing this?
    2009-03
    Somerville, MA
    669
    Hi, Rodger. Welcome to the forums for your first post.
    Can you post an image of what you are getting or better yet a sketch of what you want to accomplish?
  1. how to make curved window with curved arch trim in curved wall
    By lcollot in forum Revit Architecture - Families
    Last Post: 2008-01-21, 01:46 PM
  2. Is there a way to 'fudge' the display of a curved grid?
    By Dave F. in forum Revit Architecture - General
    Last Post: 2007-04-19, 10:20 PM
  3. curved curtain grid
    By RobG in forum Revit Architecture - General
    Last Post: 2006-03-28, 10:20 PM
  4. Grid Head / Grid lines on separate export layer
    By Griff in forum Revit Architecture - General
    Last Post: 2004-02-10, 09:02 PM
