Thread: Action Recorder and MTEXT
    2011-12
    Angry Action Recorder and MTEXT
    Has anyone successfully used MTEXT within the Action Recorder? When I insert MTEXT with or without "user input" option it will not playback allowing me to insert new text and/or place the text box where needed. In 2010 version I had no problem using this command inside an action recorded macro.
    Default Re: Action Recorder and MTEXT
    Good morning,
    for Mtext . action recorder did not work. becoz it takes simpel in put not window based.
    for text editing, fist i explode that text . then i select that text and change its property..
  1. What do you use Action Recorder for?
    By mountpelepele in forum AutoCAD Action Recorder
    Last Post: 2017-10-10, 09:19 PM
  2. Action Recorder save as to VB or C#
    Last Post: 2017-07-14, 02:43 PM
  3. 2011: Problem with Action Recorder
    By Borgster in forum AutoCAD General
    Last Post: 2011-03-09, 03:46 PM
  4. Invoking Action Recorder
    By s_depc in forum AutoLISP
    Last Post: 2010-07-23, 10:32 PM
Tags for this Thread
