Results 1 to 10 of 13
Thread: DWG tracing problem
    2004-05
    792
    Unhappy DWG tracing problem
    Trying to trace a dwg underlay for walls. It worked last night but today we can no longer snap to the underlay even when tabbing.
    Any thoughts would be appreciated!
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: DWG tracing problem
    One thought.
    Workset job? Check active worksets.
    2004-05
    792
    Thanks, but no workset is being used.
    2004-05
    792
    imported the same dwg into another revit session and no problems slecting or snapping to any lines.
    2002-02
    St. Louis, MO
    4,695
    /Check the obvious first - are snaps on? Settings->Snaps
    2004-01
    Columbus Ohio
    60
    Aaron, since you brought up snaps, I have my personal favorites and would like to set them once and be done with it instead of resetting everytime I start up. I've tried templates and for some reason after the 2nd load the template file goes haywire and Revit has reset everything back to default. So far this was the most success I've had (if you can even call that success) This is only one on a list of many things that Revit will allow users to modify 'in session but refuses to remember anything once the session is closed. I've tried everything I can think of and I'm beginning to think there is no hope of customizing thins to my preferences/work habits. Any pointers?
    Thanks
    2002-02
    St. Louis, MO
    4,695
    Yep. Turn them all on and forget about them. Revit is pertty automatic with snaps unlike AutoCAD. As the help file says - settings are not saved - they apply to all open drawings for only that Revit session.
    I could stop if I wanted to Merlin's Avatar
    2004-05
    Brisbane, Australia
    405
    OK....I had a similar problem once.....I was trying to trace on an imported .dwg file and couldn't snap...I discovered that I had imported the .dwg file on one level floor plan and I was trying to trace over it while I was in a floor plan that was above the first....just check that first and get back to us
    John Mc
    2004-05
    792
    yeah, we tried reimporting it as well, still nothing. Did notice an error box saying it could not center the import and would'nt. We used automated settings. We put in manually in the same level and it worked.
    I recall many months ago we had a similar problem when importing and not being able to accept the default centering options. We had to manually do it.
    2004-05
    Brisbane, Australia
    405
    Quote Originally Posted by sjsl
    ........I recall many months ago we had a similar problem when importing and not being able to accept the default centering options. We had to manually do it.
    I try not to center an imported drawing as that can vary too much, particularly if you import more than one .dwg file. I find it crucial that all .dwg files have a common, 0,0,0 co-ordinate and import automatically using "origin to origin". This also makes for less problems within AutoCAD when using x'refs.
    Still, it doesn't help your original problem....I'm toying around with it now...I'll re-post/message/e-mail/whatever if I come up with anything.
    John Mc
    PS....hold on....now I think about it, I think I recall that I hot-keyed a particular snap (even though they were on) and it accepted that....give that a shot.
  1. Tracing a cad drawing
    By cadgiri in forum Revit - Student Support
    Last Post: 2013-03-13, 03:03 PM
  2. Insert PDF for tracing
    By dzatto in forum Revit Architecture - General
    Last Post: 2010-03-05, 07:18 PM
  3. OLE Object tracing
    By tim.williamson in forum AutoCAD LT - General
    Last Post: 2004-09-27, 08:07 PM
