Thread: how to add material in baluster
    2011-07
    INDIA
    7
    Default how to add material in baluster
    Hi
    i am using revit 2011 & 2012 but i cannot add a material in baluster.
    can you tell me how can in add material in it.
    i didnt find any option in type property to select the material but there was an option for railings.
    Is adding of material for baluster possible?
    please help me
    you can mail in sudarshankvarma007@gmail.com
    Thank you
    Sudarshan K Varma
    2009-03
    Somerville, MA
    1,060
    Default Re: how to add material in baluster
    There are two ways to control the baluster materials: by type or globally.
    By type: In the Project Browser > Families > Railings, edit your baluster type. There should be a category for "Baluster Material". All set.
    Globally: You can control the all balusters in the project with "Baluster Material" set to <By Category> through the Manage tab > Object Styles > Model Objects tab, Railings > Balusters. This is a global setting for the whole project that will affect every baluster (that is set to by category).
    Hope that helps!
  1. Host Sweeps material not showing up on a material schedule
    By wadeshuey in forum Revit Architecture - General
    Last Post: 2011-09-23, 07:13 PM
  2. Baluster Material
    By stephanschneller in forum Revit Architecture - General
    Last Post: 2010-06-09, 08:53 AM
  3. Unable to Change Baluster Material
    By qetuo_s in forum Revit Architecture - General
    Last Post: 2010-03-15, 02:36 PM
  4. Baluster, Baluster - Post and Baluster - Panel
    By phyllisr in forum Revit Architecture - Families
    Last Post: 2009-10-15, 03:27 PM
  5. Baluster material
    By Exar Kun in forum Revit Architecture - General
    Last Post: 2005-03-09, 05:51 AM
