Thread: Change default profile settings
    2003-03
    Omaha, Nebraska
    18
    Default Change default profile settings
    Id like to change our default profile settings such as some of the labels and prefixs. Is there a simple way to do this? Maybe a file i can edit or even if i knew the command i could use lisp.
    Chris Napierala
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,446
    Default Re: Change default profile settings
    under the Project-Prototype Manager, you can define multiple "templates" ( actually Prototypes) with various settings that you want and them save them as a new prototype. Once you have them defined, simply use that prototype when you create a new project. Changing in midstream can be a bit tricky though. You can write a routine to modify many properties while in a drawing session, and some can be manipulated in the dfm file(s) associated with the project and\or drawings.
    2015-12
    Arizona
    2,478
    Or while in the file use Profiles>Profile Settings>Profile Layers to adjust them
    on a project by project basis.
    1,446
    Or, on another note. If you are just looking to change the layer properties, you can always write a script routine to just change properties of the default layers and run it after you have your profiles created. Something along these lines....
    ;;;Set Profile Layers
    -layer c 251 *PBASE c 1 *PEGC c 251 *PVGRID,*PGRID c 4 *PGRIDT c 1 *PEGL* , *PEGR*
    -layer c 3 *PFGC,*PFGL,*PFGR,*PFGR*,*PFGL* c 2 *PFGCT,*PFGLT,*PFGRT
    -layer lt DASHED2 *PEGC,*PEGR,*PEGL
    save this as an scr file and then run it. The reason I have the * in front is to include all layers that have the alignment name attached to them. Make sure that you watch which layers you are setting in order when using wildcards though. An example is the PFGR layers, with the wildcard at the end, it will change the text layer also, so you will need to add the text layer setting after setting the ones for the profile linework.
  1. 2013: change default settings on dwg-to-pdf converter?
    By aenglish902566 in forum AutoCAD Plotting
    Last Post: 2013-04-08, 07:47 PM
  2. change default settings
    By houston.cad in forum Revit Architecture - General
    Last Post: 2011-02-28, 09:08 PM
  3. default settings
    By cookie in forum Revit MEP - General
    Last Post: 2009-05-28, 12:51 PM
  4. change all entities to default settings
    By james.126519 in forum AutoLISP
    Last Post: 2008-07-17, 06:37 PM
  5. Default settings
    By costas.vassiliou in forum AutoCAD General
    Last Post: 2004-07-29, 09:42 AM
