Thread: Revit bathroom families made in Inventor
    All AUGI, all the time clog boy's Avatar
    2006-12
    Probably near a PC.
    843
    Default Revit bathroom families made in Inventor
    It is a pain in the neck to make most plumbing fixtures (toilets, baths, sinks etc) look good in Revit. Usually I have to rely on a dxf volume and use masking regions and dwg 2D imports to end up with anything that remotely resembles the finished product. I have tried to make or adapt existing Revit volumes, usually to no avail. And using different tools to make different views of the same building component representation isnt really the way to go IMO.
    What I was wondering is whether someone has made the effort to create basic bathroom families in Inventor which I can use in Revit, or whether there is another good resource for families that look consistent without too many hacks.
    Sincerely, Bram
    2015-08
    84
    Default Re: Revit bathroom families made in Inventor
    What kind of things are you looking for? Creating the plumbing fixtures simply requires a good sculpting sense. Lots of voids, using every solids tool available...
    2006-12
    Probably near a PC.
    843
    Quote Originally Posted by contact.andrewk968454 View Post
    Revit tools are frustrating for that level of detail at best. If it had prettier shaders for dxf imports (without showing that ugly grid pattern) then that's all I would need.
  1. Where to get 3d revit free kitchen and bathroom component
    By speedfreak5150 in forum Revit Architecture - Families
    Last Post: 2016-02-04, 02:24 PM
  2. 2014: Thanks for all the tips, here's some families i've made
    By PabloNZ in forum Revit Architecture - Families
    Last Post: 2014-04-30, 09:54 PM
  3. Revit User Guide Graphic made in Revit?
    By tklein.208994 in forum Revit Architecture - General
    Last Post: 2010-10-06, 01:52 AM
  4. Revit MEP 2009 Bathroom Riser
    By blueyes42 in forum Revit MEP - General
    Last Post: 2009-05-04, 01:12 PM
