Thread: Default Beam Annotation Placement
    2010-04
    7
    Default Default Beam Annotation Placement
    Can anyone tell me where or how you change the default location of where beam annotations are placed? When you go into the Beam Annotation dialogue box and click on the Settings box you have the opportunity to either use the default Vertical Offset or specify your own. The default is 3/8" - where do you change that?
    2002-06
    North Central CT
    1,108
    Default Re: Default Beam Annotation Placement
    In the BEAM ANNOTATIONS dialog box click the SETTINGS... button. You can then specifiy the offset distance you want. Just keep in mind that this does NOT apply to manually placing beam tags (unless there's some other option I haven't seen).
    Matt
  1. Beam Annotation Tool Bug
    By david_peterson in forum Revit Structure - General
    Last Post: 2013-07-09, 03:08 PM
  2. 2D Annotation placement for receptacle families
    By Jason Roy in forum BIM Management - General
    Last Post: 2011-10-14, 05:51 PM
  3. Annotation won't print when in advanced placement
    By nightNday in forum AutoCAD Map 3D - Annotations
    Last Post: 2009-04-17, 04:37 PM
  4. Beam placement within beam systems?
    Last Post: 2007-02-28, 06:59 PM
  5. How to control Leader Placement in Annotation Families?
    By paul.mullis in forum Revit Architecture - Families
    Last Post: 2006-08-22, 06:41 PM
