Thread: Array issue
    AUGI Addict mattw's Avatar
    2002-06
    North Central CT
    1,007
    Default Array issue
    Attached is one of the OOTB shear plate families from RS. I want to do something similar to the array of circles in one of our families but I can't quite figure out what the factory did. I added the squares (separate family) to the shear plate family then added an array and assigned my array the same parameter as the factory-made array. But mine isn't functioning the same. When you flex the family, you'll notice that the array of circles spaces itself evenly when the plate is lengthened/shortened where as my array of squares just sort of sits there. When you change the Number of Holes parameter, the number of circles and squares changes so I at least got THAT correct.
    Any thoughts?
    Matt
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    599
    Default Re: Array issue
    you forgot to lock 1st + last square to reference planes
    2002-06
    North Central CT
    1,007
    Perfect. Thanks! I think I was spending too much time on it, trying to over-analyze it. :\
    Matt
  1. Curtain Panel Louvre Array Height Issue
    By wearethestones in forum Revit Architecture - Families
    Last Post: 2008-06-26, 08:32 PM
  2. Issue With Nested Array
    By blusurfer in forum Revit Architecture - Families
    Last Post: 2008-05-13, 01:28 AM
  3. Window with Array of Mullions but Array Group Doesn't like Constrants!
    By billyn in forum Revit Architecture - Families
    Last Post: 2007-07-18, 02:03 PM
  4. Parametric Drawer Front with array (problems controling array)
    By robert.manna in forum Revit Architecture - Families
    Last Post: 2007-04-04, 05:17 AM
  5. Titleblock - issue date and type of issue placed in issue column
    By jdrexler in forum CAD Management - General
    Last Post: 2006-04-10, 05:01 PM
