Thread: Display Order of Objects Drawn in Paper Space
    2008-01
    21
    Arrow Display Order of Objects Drawn in Paper Space
    I've drawn hatch object in paper space for some purpose. While plotting, I want to change the display order of it so that hatch will be as a background in plot. Is it possible?
    Note: I don't want to take the hatch objects to model space (by Modify-->Change Space command) !!!
    Cairo - no, not Illinois
    2,714
    Default Re: Display Order of Objects Drawn in Paper Space
    I don't believe that you can do that -- AFAIK draworder cannot work between spaces.
    but there may be a workaround that will give you the effect you need, no guarantees tho.
    In the PLOT dialog, Uncheck the box that says "Plot PaperSpace Last", and make sure that Lines Overwrite is enabled instead of Lines Merge (That should be under the Properties button of the plotter, - see the Device and Documents Settings tab, and expand the Graphics item)
    Of couse, the most reliable way would be to move the hatch to Mspace, and set it to the back. quit without saving if you do not want to leave it there.
    Officially Awesome
    2008-01
    21
    Thanks!!! Its working with "Plot Paperspace Last" option settings. If finding any problem, discuss again on it.
  1. Display order - Paper vs. Model space
    By bill.briggs in forum AutoCAD General
    Last Post: 2009-01-05, 07:24 PM
  2. Paper space Display
    By ekohles in forum Design Review - General
    Last Post: 2008-05-13, 08:28 PM
  3. OBJECTS DONT DISPLAY MODEL/ PAPER SPACE
    By dbrownson in forum AutoCAD General
    Last Post: 2008-04-03, 11:44 PM
  4. Display order in Paper Space....
    By bjack56 in forum AutoCAD General
    Last Post: 2005-01-10, 07:35 PM
