Hello,
Can anybody tell me if it is possible, and how, to move pipes between networks?
Hello,
IF, I understand the request,
Select the Pipe, From the Ribbon Menu select SPLIT NETWORK
Use option to make a new network from the split parts.
Select pipe in the newly split network
From the Ribbon Menu select MERGE Pipe Networks
Merge the two networks together
Or
Select the pipe
Rt-click>>>Connect to Part, select the structure you wish to connect the pipe to.
