A method that I find works well is the following:Quote:
Question 4: Could you recommend method to create brick shelf in conc. fdn. wall?
I've found it easiest to do a host sweep at the edge of slab -- then join that geometry to the foundation wall at the detail level.
If you have a 12" foundation wall with a 4" brick shelf, create the wall with one 8" layer of concrete and one 4" layer of concrete.
You can then unlock the top of the 4" layer, and lower it either by dragging it or via the properties dialog.
