Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Image Shifting
  1. #11
    2001-10
    Arizona
    2,337
    Default Re: Image Shifting
    Does this also happen IF the image is added through MAP workspace?
    Also can you provide a direct link? I grabbed some SID file(s) for POLK county however the file names do not seem to align with the ones in your file as posted.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
  2. #12
    2012-01
    Baxter, MN
    8
    I use Raster Design to attach the images, not MapConnect or MAPIINSERT. I can't really provide a direct link to the file since its downloaded and attached. The USDA/NRCS site only has download options, not link to options.
    Its not a Raster Design issue, looked at that. Its not a coordinate transformation issue because in model space the image is on the correct coordinates.
  3. #13
    2001-10
    Arizona
    2,337
    The link I was asking for was exactly where and on what site you originally acquired the image from.
    Is your view set to Othographic or Parallel projection?
    Be your Best,
    Michael Farrell
  4. #14
    2012-01
    Baxter, MN
    8
    Link to USDA/NRCS site: http://datagateway.nrcs.usda.gov/
    View is set to Orthographic (PLAN) projection (looked at that already).
  5. #15
    Civil Engineering Moderator civil3Dguide's Avatar
    2006-01
    Temecula, CA
    281
    I've seen this issue also. User had 2 viewports on the same sheet layout, image was shifting when plotting. The viewports showed the same image, but different sections of it, when plotting both viewports would show the same area of the image.
  1. sid, ecw image shifting in paperspace vs model space
    By julie.248605 in forum Geospatial - General
    Last Post: 2012-07-17, 04:23 PM
  2. PDF shifting on Plot
    By kbrett in forum AutoCAD Plotting
    Last Post: 2008-02-28, 04:39 PM
  3. Shifting IDW Views
    By Mike Y in forum Inventor - General
    Last Post: 2008-02-04, 02:44 PM
  4. MVBlocks Shifting
    By dhallett in forum ACA General
    Last Post: 2007-09-14, 09:07 PM
  5. shifting columns
    Last Post: 2005-05-23, 08:01 PM
