Results 1 to 10 of 10
Thread: Drawings vs Documents Dept Battle
    2003-09
    2
    Exclamation Drawings vs Documents Dept Battle
    Hey Folks . . a battle is starting to rage where I work.
    The Records Dept that handles storage of all letters, manuals, specs etc now wants to control all AutoCAD Files.
    Does any one have ideas I can use against this crazy plot?
    Lke the Differences between a Drawing and a Document.
    I am talking about the electronic CAD files not the historic paper printouts.
    100 Club Globey's Avatar
    2002-07
    Newington, Ct
    164
    Default Re: Drawings vs Documents Dept Battle
    What type of vault software are they using for storing the electronic cad files?
    Cyco Systems had a pretty good storage software program, for vaulting autocad files, but it was difficult to master...and time consuming to pull up old drawings...
    If they think they can just lump it all onto some separate server....good luck looking things up after that....
    "Frisbeetarianism is the belief that when you die, your soul goes up on the roof and gets stuck.- George Carlin
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    Give em a copy of AutoCad and make them figure it out.
    After a long walk off a short peer, they will forget about it.
    2003-09
    2
    We are using Cimage right now to hold completed drawings but the Record Dept is switching every dept over to something called Live Link.
    The Record Dept head is power hungry, she wants to even take control of E-mail, and all scanners and printers away from the I.T. Dept . . . cause they generate documents.
    2002-07
    Newington, Ct
    164
    http://www.amsystems.com/products/cyco/index.asp
    Have them take a look at that link...automanager workflow was a good program, but somewhat hard to get used too, but it was worth it...and I used it years ago....so it would be much better and easier to use now I would imagine...
    2001-05
    Austin, TX USA
    2,201
    Quote Originally Posted by gfoley
    Next thing you know, they will want to take over your computers and cad software.....cause they generate documents.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    100 Club Kris.Keller's Avatar
    Rigby, Idaho
    106
    We lost the battle years ago. Once we release our drawings they get stored electronically in our document control group.
    Certified BIM Addict Brian Myers's Avatar
    2003-02
    Working in Cyberspace
    1,682
    Question: In what way will this effect the way your department does its work? I assume you'll still control drawing file creation and modification via a network. Are we talking a simple change in file storage location and back-up or are we talking something much more involved? In short: As we're not familiar with the practices and hardware/software capabilities of your department and company, what is the scope of the change we are talking about?
    Brian Myers
    Sr Applications Engineer, Seiler Instrument | Autodesk Certified Instructor (ACI) Revit Architecture
    Creator of the Revit Users LinkedIn Community | Author of Revit Videos @ Lynda.com
    Active Member Ms. Serene's Avatar
    2004-08
    Tucson Arizona
    89
    why are they interested in the AutoCAD file? The signed drawings should be what they are interested in because that's what counts legally.
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    Theres an ad on page 17 of the 2005 jan/feb AUGI world issue for file management geared towards autocad.
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
  1. Maison individuelle dépt 06
    By pcamliti in forum Revit Architecture - Gallerie
    Last Post: 2011-06-06, 07:58 AM
  2. Making CAD Drawings Searchable PDF Documents
    By dalplummer in forum CAD Management - General
    Last Post: 2011-03-20, 08:03 PM
  3. 2011: problem openeing drawings from "recent documents"
    By jmctamney in forum AutoCAD General
    Last Post: 2010-11-29, 06:12 PM
  4. The PDF vs DWF battle heats up with Acrobat 7.0
    By Scott Davis in forum Revit - Plotting/Printing/Exporting
    Last Post: 2004-11-23, 08:06 PM
