Results 1 to 6 of 6
Thread: Replace Selected Block(s)
    2006-03
    San Cristobal, Guatemal
    439
    Default Replace Selected Block(s)
    I am looking to replace a group of selected blocks with a different block, not the (global) block replacement that is currently available with express tools. Can anyone assist me? Thanks.
    Member vmichl's Avatar
    2002-04
    C.Budejovice, Czechia
    34
    Default Re: Replace Selected Block(s)
    Please try RIblock described in the following tip:
    http://www.cadforum.cz/cadforum_en/h...-block-tip7038
    Vladimir Michl, www.cadstudio.cz
    Cairo - no, not Illinois
    5,069
    you know, a metric boat load of people are uncomfortable/unwilling to run compiled code...... If I can't see what's happening under the hood so to speak, I'm not apt to load or run it.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Quote Originally Posted by Darren Allen View Post
    Here is one solution. Select the group of blocks you want to change, cut/paste them into a new drawing, then use the global block replace from Express Tools. After you have the blocks changed, cut/paste them back to the original drawing.
    2007-08
    Rockford, Illinois
    161
    I have a simple program on my free download site called Rinsert.lsp that will replace single or multiple selected blocks.
    http://www.engds.com/FreeDownloads/Downloads.html
    It requires a utility file which is noted (also free) and also adds other useful routines to your toolbox.
    2006-03
    439
    Quote Originally Posted by vmichl View Post
    What is the command Line Prompt?
    Nevermind - I found it, Thanks
  1. Replace Selected Blocks with Attributes
    By traci.242201 in forum AutoLISP
    Last Post: 2013-10-14, 07:19 PM
  2. Adjustment to the Replace Selected Command
    By tra1133 in forum ACA Wish List
    Last Post: 2012-11-29, 05:14 AM
  3. 2012: Replace Selected Detail Component Manager Item in Place
    By tra1133 in forum ACA General
    Last Post: 2012-11-28, 01:15 AM
  4. Replace Selected Edge in Frame Generator
    Last Post: 2008-10-04, 06:13 PM
  5. Find and Replace within Selected Cells in a Table
    Last Post: 2007-09-27, 12:04 PM
