Thread: Render - Pump room with chilled water piping
    2007-11
    Dallas, TX - USA
    352
    Default Render - Pump room with chilled water piping
    Here's a rendering of a job I'm working on. Modeled and rendered using AutoCAD MEP 2011 only. Showing here is an expansion tank with the supply and return piping using 12" diameter pipe on a triple pump hydronic system. No hangers, etc... just preliminary equipment placement and overhead pipe routing options.
    2005-07
    12
    Default Re: Render - Pump room with chilled water piping
    Nice, I would love to see it with hangers and the small bore piping!
    ACA/AMEP Community Chair stelthorst's Avatar
    2003-10
    San Francisco CA
    1,190
    Very nice Tannar,
    The only way to make it look more realistic would be to add a bunch of trash, mouse traps, and storage boxes. (or is that just the pump rooms I'm used to seeing?)
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    Some see the glass as half full, others as half empty. As an engineer I see the glass as twice as big as it needs to be. ~Unknown~
    2016-01
    Saudi Arabia
    101
    VARY NICE WORK........
  1. CONTROL WATER PUMP PROGRAM
    By justinweihong683244 in forum AutoLISP
    Last Post: 2014-11-13, 09:02 PM
  2. Is there a way to separate Waste and Water piping?
    By NATHAN46290 in forum Revit MEP - General
    Last Post: 2009-11-04, 04:25 AM
  3. Chilled Beam Family?
    By s.messing in forum Revit MEP - Families
    Last Post: 2007-10-06, 01:53 AM
  4. 3ds MAX - Living Room Render
    By dellis in forum DV - Gallery
    Last Post: 2007-04-13, 02:58 PM
  5. Training room render
    By hofe_design in forum AutoCAD Gallery
    Last Post: 2005-10-07, 06:55 AM
