View Poll Results: Helpful
Voters
1. You may not vote on this poll
  • Yes
    1 100.00%
  • Slightly
    0 0%
  • Maybe
    0 0%
  • No you jerk
    0 0%
Multiple Choice Poll.
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Intersection Wizard--Curb Return
  1. #11
    2008-12
    23
    Default Re: Intersection Wizard--Curb Return
    Our survey department always starts each alignment at 10+00 going AWAY from the intersection This is a problem with the 4 way intersection also. I have to join the alignments and reverse the direction so I end up with only 2 alignments that meet at the intersection.
    Bruce
  2. #12
    2001-10
    Arizona
    2,337
    Quote Originally Posted by bruce.klug View Post
    Bruce
    Just asking; why not have a design centerline, in your DESIGN file(s) that is contiinous (normal)
    And then let the Surveyors have their own alignments that do whatever they think they need to do with them, in a SURVEY file, or on Survey Layers?
    I wont ask you to explain why, because I'm sure someone has gone to a lot of work to justify doing them that way. And they certainly wont change just becuase someone asks them to.
    I've been in this business since 1978, and have never worked anywhere that wanted to treat alignments in that manner. And if you think about it logically they can not ALL start at Ten plus Zero Zero and go away from an intersection. Like what happens from block to block? Somewhere in the middle does it start counting down to 10+00 again?
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
  1. Skylight with curb
    By FrenchQuarters in forum Revit Architecture - Families
    Last Post: 2010-11-12, 11:00 PM
  2. Curb grading
    By suji_rash in forum AutoCAD Civil 3D - Grading
    Last Post: 2007-01-08, 02:12 PM
  3. Dimensioning and intersection or aparent intersection a no go.
    By kb3cxe in forum AutoCAD LT - General
    Last Post: 2006-05-08, 04:32 AM
  4. How do you create a Boxed Return or Cornice Return?
    By rgecy in forum Revit Architecture - General
    Last Post: 2004-05-20, 04:42 PM
Tags for this Thread
