I'd like to change the XREF(s) "Saved Path" to the "Found at" location using LISP.
I know I can do it by using CLASSICXREF ... "Saved Path" button, but would like to do it at startup via LISP.
Give this a try:
Code:;;;--------------------------------------------------------------------; ;;; XrefPaths fundtion: (defun XrefPaths () (vl-load-com) ((lambda (acDoc / oBlocks oXref) (vlax-for oItem (vla-get-filedependencies acDoc) (if (and (= "Acad:XRef" (vla-get-feature oItem)) (setq oXref (vla-item (cond (oBlocks) ((setq oBlocks (vla-get-blocks acDoc)))) (vl-filename-base (vla-get-filename oItem))))) (vla-put-path oXref (vla-get-fullfilename oItem))))) (vla-get-activedocument (vlax-get-acad-object))) (princ)) ;;;--------------------------------------------------------------------; ;;; Autorun XrefPaths fundtion: (XrefPaths)
Computer Specs:
