Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: lisp table help
    Default lisp table help
    hey there
    mij name is kevin and i'm having a littel troble whit a lisp i'm tring te create
    i want to create a table which uses extracted data from multiple blocks these bloks all have atributes addet to them whit diverent values
    more or les it needs to look like this
    name
    block1/amount/value1/value2/value3
    block2/amount/value1/value2/value3
    block3/amount/value1/value2/value3
    includit are two sampels of the block that i use and a example
    sampel.dwg
    I could stop if I wanted to pbejse's Avatar
    2010-10
    395
    Default Re: lisp table help
    From the looks of it you used Dataextraction.
    So what wrong with it?
    if you already have the DXE file. you can use
    (defun Itable (path)
    (command "-dataextraction" path)
    (Itable "c:\\path\\template.dxe")
    And you will be prompted for the insertion point.
    Quote Originally Posted by pbejse View Post
    And you will be prompted for the insertion point. Cannoscale variable will take care of the scaling for you
    maby but then i cant select wich blocks i wanto ad
    and it changes it it becomes likesampel.dwg
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,210
    Try this routine but I'm not sure if it will be work for your Acad release
    Mine is A2009, this lisp is working good in there
    (defun C:Bomt(/  acsp adoc atable attdata attitem atts blkdata blkname blkobj col datalist
    		  en headers pt row sset tabledata tags total txtheight x)
      ;local defun
      (defun sum-and-groupby-all (lst / groups res sum tmp)
      (while lst
        (setq tmp	    (car lst)
    	  sum
    		    (apply '+
    			   (mapcar 'car
    				   (setq res (vl-remove-if-not
    					       '(lambda (a) (vl-every 'eq a tmp))
    					       lst
    	  groups    (cons (subst (itoa sum) (car tmp) tmp) groups)
    	  lst
    		    (vl-remove-if
    		      '(lambda (a) (member a res))
    		      lst
     (reverse groups)
    ;main part
      (if (setq sset (ssget (list (cons 0 "INSERT") (cons 66 1))))
        (progn
          (setq tabledata nil
    	    attdata nil
    	    attitem nil
          (setq headers (list "Count" "Name" "SCH" "PLEN" "INHEI" "AFHAK" "SLEN" "PWAP" "DRAAGF" "TREKF")
    	    tags    (cddr headers)
          (while (setq en (ssname sset 0))
    	(setq blkobj  (vlax-ename->vla-object en)
    	      blkname (vla-get-effectivename blkobj)
    	(setq atts (vlax-invoke blkobj 'getattributes))
    	(foreach attobj	atts
    	  (if (member (vla-get-tagstring attobj) tags)
    	    (progn
    	      (setq attitem (cons (vla-get-tagstring attobj) (vla-get-textstring attobj)))
    	      (setq attdata (cons attitem attdata))
    	(setq blkdata (append (list 1 blkname) (reverse attdata)))
    	(setq tabledata (cons blkdata tabledata))
    	(setq attdata nil
    	      attitem nil
    	(ssdel en sset)
          (setq tabledata (mapcar '(lambda (x)
    				 (append (list (car x) (cadr x))
    					 (mapcar 'cdr (cddr x))
    			      tabledata
          (setq tabledata (sum-and-groupby-all tabledata))
          ;; sort by "SCH" :
          (setq tabledata (vl-sort tabledata '(lambda (a b) (< (caddr a) (caddr b)))))
          (setq total 0)
          (foreach i datalist (setq total (+ total (cdr i))))
          (or (not (zerop
    		 (setq txtheight
    			(getvar "textsize")
    	  (setq txtheight 54.0)
          ) ;<-- text height as for as in your drawing
          (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
          (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc))))
          (setq pt (getpoint "\nSpecify table location:"))
          (setq atable (vla-addtable
    		     acsp
    		     (vlax-3d-point pt)
    		     (+ 2 (length tabledata))
    		     (length headers)
    		     (* txtheight 2)
    		     (* txtheight 8)
          (vla-put-regeneratetablesuppressed atable :vlax-true)
          (vla-put-horzcellmargin atable (* txtheight 0.5))
          (vla-put-vertcellmargin atable (* txtheight 0.3))
          (vla-setTextheight atable 1 txtheight)
          (vla-setTextheight atable 2 txtheight)
          (vla-setTextheight atable 4 txtheight)
          (vla-setText atable 0 0 "Bom")
          (vla-SetCellAlignment atable 0 0 acMiddleCenter)
          (setq col -1)
          (foreach descr headers
    	(vla-setText atable 1 (setq col (1+ col)) descr)
    	(vla-SetCellAlignment atable 1 col acMiddleCenter)
          (setq row 2)
          (foreach record tabledata
    	(setq col 0)
    	(foreach item record
    	  (vla-setText atable row col item)
    	  (vla-SetCellAlignment atable row col acMiddleLeft)
    	  (setq col (1+ col))
    	(setq row (1+ row))
          (vla-put-regeneratetablesuppressed atable :vlax-false)
    (princ)
    (prompt "\n Styart command with BOMT...\n")
    (prin1)
     (or (vl-load-com))
    (princ)
    ~'J'~
    "The whole problem with the world is that fools and fanatics are always
    so certain of themselves, and wiser people so full of doubts."
    Bertrand Russell
    2001-12
    54
    Quote Originally Posted by fixo View Post
      ;local defun
      (while lst
        (setq tmp	    (car lst)
    	  sum
    		    (apply '+
    			   (mapcar 'car
    					       lst
    	  lst
    		    (vl-remove-if
    		      lst
     (reverse groups)
    ;main part
        (progn
          (setq tabledata nil
    	    attdata nil
    	    attitem nil
    	    tags    (cddr headers)
    	    (progn
    	(setq attdata nil
    	      attitem nil
    	(ssdel en sset)
    			      tabledata
          ;; sort by "SCH" :
          (setq total 0)
          (or (not (zerop
    		 (setq txtheight
    			(getvar "textsize")
    		     acsp
    		     (vlax-3d-point pt)
    		     (length headers)
    		     (* txtheight 2)
    		     (* txtheight 8)
          (setq col -1)
          (setq row 2)
    	(setq col 0)
    	  (setq col (1+ col))
    	(setq row (1+ row))
    (princ)
    (prin1)
     (or (vl-load-com))
    (princ)
    ~'J'~
    Fixo: where in the program does someone change the size or scale of the table ?
    regards and TIA, Steve
    2005-05
    Pietari, Venäjä
    1,210
    Hi Steve,
    Do you want to scale the whole table or
    just sparate rows/columns?
    If the first one then easy to apply (vla-scale... ) or
    command "scale" to do work or just change txtheight variable
    within the code accordingly to your standard text height
    Regards,
    Oleg
    Bertrand Russell
    2001-12
    54
    Smile Re: lisp table help
    Hi Steve,
    Regards,
    Oleg
    Thanks for help Oleg:
    I found that textsize setting in Acad was controlling the table size even though the setting for txtheight was set to what I wanted it to be. Setting them both the same did the trick.
    Steve
    2005-05
    Pietari, Venäjä
    1,210
    You're welcome, Steve
    Cheers
    Oleg
    Bertrand Russell
    2009-10
    8
    Hi Oleg and others,
    I read this thread with interest because I have a requirement for something very similar.
    I have created a drawing (attached) with two "Tag to Table" requirements.
    I am wondering if this is something that would not take much time to solve.
    I tried altering your code myself, but had difficulties. (I am not so familiar with lisp), I do not need the tag name. I also notice that the first attribute is ignored in your code.
    Anyway, I would of course be grateful for any assistance in this.
    Additional queries......Is there a way of fixing the table column widths to match the length of text? Is it possible to do a direct export of a table to Excel with columns and rows being the same?
    Gosh! I am asking for a lot.
    Rgds from hopeful me.
    2005-05
    Pietari, Venäjä
    1,210
    Quote Originally Posted by mark.232312 View Post
    Hi Oleg and others,
    Hi Mark
    Welcome on board
    I can't do it right now by reason of we have here
    the holyday, but I will be back as soon as possible
    Have a great day
    Oleg
    ~'J'~
    Bertrand Russell
  1. AU2006 LISP Table Magic
    By peter in forum AutoLISP
    Last Post: 2013-04-11, 03:16 PM
  2. Inserting blocks in table cells using LISP
    By costas.vassiliou in forum AutoLISP
    Last Post: 2013-03-06, 07:26 PM
  3. block and table lisp
    By john.237249 in forum AutoLISP
    Last Post: 2012-01-20, 03:35 AM
  4. Curve Table Lisp Routine
    By julie.206712 in forum AutoLISP
    Last Post: 2011-10-18, 04:55 PM
  5. Setting Plot Style Table in Lisp
    By fletch97 in forum AutoLISP
    Last Post: 2007-01-30, 08:43 PM
