Thread: DB apperance depending on attribute value
    2009-01
    Warsaw Poland
    130
    Default DB apperance depending on attribute value
    I have copied this thread from Dynamic Blocks subforum and I hope I will have more luck here
    ___________________
    I'm wondering if there is a possibility to change block apperance (for example dimensions) by attribute value?
    For example lets say that I have DB with just linear stretch and I want my DB to read stretch value from attribute value. If YES, Then I'm able to export/import attributes and automaticaly change dimensions of multiple blocks.
    I've prepared test DB block to show what I would like to achieve.
    Block contains two attributes (lenght_att, height_att) and two streatch actions based on two parameters (lenght_parameter, height_parameter).
    Because I have attributes I have possibility to do export/import attribute data. And I would like sth to read/write attributes value into parameters value:
    lenght_att >>> lenght_parameter
    height_att >>> height_parameter
    www.cadforum.cz/forum_en/uploads/38935/test.dwg
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,096
    Default Re: DB apperance depending on attribute value
    Quote Originally Posted by Macieto View Post
    Please do not do that in the future. It is against the Forum Guidelines and may lead to the removal of duplicate threads.
    You would need to find all of your desired blocks through a selection set. Of course, being dynamic blocks, you pretty much have to select all blocks. After you have your initial selection, you will need to run through them one time to filter out the blocks that do not have an EffectiveName of your desired dynamic block. (Of course, you can decide to run through this list only once and act on it depending on the EffectiveName of the block.) Now that you have your list of blocks, you would process these blocks to extract the attribute values to assign to the parameter values.
    I'm sure someone has done something similar to this and posted it here. However, the specific tasks mentioned above are posted in these forums. You just may have to combine them to make a coherent routine to automate your task.
    2009-01
    Warsaw Poland
    130
    selecting the block will not be the problem because I will have it on separate layer
    Well, I will try to find it.
    Thx Opie
  1. DB apperance depending on attribute value
    By Macieto in forum Dynamic Blocks - Technical
    Last Post: 2014-10-12, 09:44 PM
  2. Load dll depending on dwg name?
    By amaser in forum Dot Net API
    Last Post: 2011-04-18, 02:14 PM
  3. Rendering Apperance in 3D Max Design 2009
    By tenghui2000 in forum Revit - Rendering
    Last Post: 2008-07-22, 01:42 PM
  4. Size Attribute depending on the DIMSCALE variable?
    By Dave F. in forum Dynamic Blocks - Technical
    Last Post: 2008-05-30, 09:06 PM
  5. Replies: 7
    Last Post: 2008-01-29, 06:11 PM
