saqib_theleo
Helo pbejse,
Updated version of this Lisp is working fine now, it is sorting right than previous one. I think 20 number is just fine, if I need a 40 to create another column then I'll try to move texts manually.
And now Horizontal sorting is not a moot point.
I am very thankful to you for your time and help.
In Last, I have a LISP (attached) which selects all texts in the drawing by making a window and moves it like MOVE command. I want to know can you make a Lisp to select only "Numeric values" OR only "Alphabetic Values". Because in some drawings Plot numbers and other texts like "Road", "Green Area" and so.. are in same LAYER which needs to be placed on their specific Layer (with attached Lisp I can do it but I have to look whether there are only numbers selected or alphatic values selected).
I don't mean to disturb you. Do it when you have time.
TAKE CARE.
Good for you saqib
If you want to change the number of lines per column
(= cnt 20) to
(= cnt 39)
As for your other request
(defun c:mtl (/ Mode sel)
(initget 1 "A N")
(setq Mode (getkword "\nEnter String type [Numeric/Alpha]: "))
(setq sel (ssget "_X"
(list '(0 . "*TEXT")
(cons 410 (getvar 'CTAB))
(cons 1
(if (eq Mode "N")
(command "_chprop" sel "" "Layer" (getvar 'Clayer) "")
(sssetfirst nil sel) ;;; <-- for you to see whats selected
;;; You can do without this line
(princ)
Hope this helps
