Thread: HELP - Changing Revit units from imperial to metric
    2012-01
    Smile HELP - Changing Revit units from imperial to metric
    Hey, i'm new
    So i was wondering, i just downloaded Revit on my new computer but the whole system seems to be in imperial, is there any way to change it, because i think i must have missed something in the installation process
    Thankyou!
    2015-12
    Vancouver, BC Canada
    3,744
    Default Re: HELP - Changing Revit units from imperial to metric
    Welcome to the forums.
    You can change the default template Revit uses for your project file and families from the applications menu (the big 'R' in the top left corner of your Revit window). Select Options and change the paths for your template and family file locations.
    If you didn't install the metric content when you first installed Revit you'll need to install it from the Windows Control panel.
    Click on your Start button, select the control panel and then Programs and Features.
    Find Autodesk Revit Architecture 2012 in your list of programs and click on the Uninstall/Change button
    From the splash screen select Add or Remove Features
    From here select the content you want to add and then click on Add Content.
    Provide a location for files if you are prompted and that should do it for you.
  1. Switching units (metric to imperial) in families
    By argman in forum Revit Architecture - Families
    Last Post: 2014-05-18, 03:53 PM
  2. Change Units From imperial to metric
    By GrD in forum AutoCAD Structural Detailing
    Last Post: 2013-10-12, 02:14 PM
  3. Converting a Survey from Metric to Imperial Units
    By marble in forum AutoCAD Civil 3D - Survey
    Last Post: 2011-11-22, 02:11 PM
  4. Imperial Units to Metric Units
    By BASE in forum Revit Structure - General
    Last Post: 2009-12-03, 11:25 PM
  5. Scale List Units Metric / Imperial
    By H-Angus in forum ACA General
    Last Post: 2008-01-23, 09:27 AM
Tags for this Thread
