Results 1 to 10 of 13
Thread: AutoCAD lost the Ribbon
    2003-09
    89
    Question AutoCAD lost the Ribbon
    We are using AutoCAD 2009 with GTX RasterCAD to edit our raster files. I am running on a Lenovo work station with Windows XP Professional. I have 3 GB of RAM and a 2.83 GHz processor. Everything was working fine Friday when I logged of but today when I opened it there was no Ribbon. All I get at the top of the page is the following message "The Ribbon does not have any tabs or panels currently attached". I can type the commands, either AutoCAD or GTX RasterCAD,and they work fine. Does anyone have an idea what happened to the Ribbon?
    2004-08
    Iron Station, NC
    3,198
    Default Re: AutoCAD lost the Ribbon
    I have no idea what happened to it, but if you reset your current workspace, it should return it, assuming the workspace hasnt become corrupted.
    2003-09
    89
    Went to change my workspace and only had two choices - 'Customize or Save Current'. My guess is that it was corrupted somehow when I logged off last week. Will try to re-install and see if that helps. Thanks for your help ccowgill.
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by jimmy.long View Post
    prior to doing a reinstall, if you open up the cui editor, you may be able to restore workspace from there, or just manually rebuild what you had on your ribbon.
    2015-12
    2,095
    It helps to stay aware of what your current Main and Enterprise CUIx files are - this determines where workspaces are saved. Some third party applications set their own CUIx as Main by default while others try to load it partial to the main. Under both circumstances they usually make it Main if there is no Main set. When the Main changes like this, AutoCAD in trying to re-establish the last used workspace and Ribbon settings, can't find things where they were and BLAMMO. Workspace gone, no Ribbon tabs 'n' panels.
    2001-03
    Tallahassee, FL USA
    3,658
    Under options set another profile current. If you don't have another one saves that fits your needs try switching back. Reloading the profile this way may fix the problem. I have a backup profile for each of the ones I use just in case. I've had the same thing happen to me before.
    2003-09
    89
    Smile Re: AutoCAD lost the Ribbon
    I tried changing my profile to the 'Vanilla' profile. I got my Ribbon back but then it could not find a bunch of dll files. Reinstalled AutoCAD and everything is back to normal.
    Turlock, CA
    6,396
    Simply switching workspaces should have done it.
    C:> ED WORKING....
    2009-01
    B5
    544
    Registry Cleaner by chance?
    Turlock, CA
    6,396
    Are you suggesting that one be used or asking if one was? They are notorious for axing acad. In either case, the ribbon is cui/file based. The registry is not involved. You can get this problem if changes were made when there is no workspace active. Switching should fix it.
    C:> ED WORKING....
  1. Autocad 2012....Lost my ribbon completely
    By Globey in forum AutoCAD General
    Last Post: 2012-09-21, 03:37 PM
  2. Lost Icons on Civil 3D 2010 Ribbon
    By 88greyhound in forum AutoCAD Civil 3D - General
    Last Post: 2009-10-27, 12:15 PM
  3. Ribbon has lost its tabs
    By Coffee Coffee in forum AutoCAD General
    Last Post: 2009-08-06, 08:03 PM
  4. Lost Ribbon and Controls in LT
    By derek.96018 in forum AutoCAD CUI Menus
    Last Post: 2009-03-18, 05:12 PM
  5. lost icon, large icons in 2009 ribbon
    By abrown in forum AutoCAD CUI Menus
    Last Post: 2008-12-15, 09:58 PM
