Thread: not all elements show vertical section
    2008-08
    24
    Default not all elements show vertical section
    When i make a vertical section of a technical room with pipe, valves and pumps only the standard global metric inline pump will not show up in all of the display sets.
    somebody knows why this happends ?
    regards
    Menno
    I could stop if I wanted to stykface's Avatar
    2007-11
    Dallas, TX - USA
    352
    Default Re: not all elements show vertical section
    The way I do it with equipment is to actually make an MvBlock. It's extra work, yes.... but anytime you're in an Elevation View it displays exactly how you want.
    See here for reference: http://dl.dropbox.com/u/4989089/Imag...ns_Details.pdf
    Everything was made in AutoCAD MEP that you see. Chiller, expansion tank, air separator, valves, pipes, fittings, etc. The difference is with the equipment as an MvBlock, I'm able to use a 2D block that I manually edit and fine tune so when I switch to an Elevation View then it looks like I want.
    Here's some reference in the ACA user guide: http://exchange.autodesk.com/autocad...bffa4-8000.htm
    Tannar Frampton | Dallas, TX | Engineering Department
    AutoCAD MEP 2012 / Revit MEP 2012 | CADTutor | The Swamp
    2008-08
    24
    Thanks for the answer,
    But i understand that not all standard elements in autocad are mvparts with different views.
    Because I use i standard pump.
    Menno
    2007-11
    Dallas, TX - USA
    352
    I didn't say MvPart, I said MvBlock, there's a difference.
    Most of the equipment you saw in the PDF were just standard 3D Solids that I created from scratch, from the submittal data direct from the manufacturer. In other words, it's a "standard" piece of equipment like you're saying.
  1. How to show vertical (station) gridlines
    By Emmar01 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2011-11-30, 02:47 AM
  2. Are vertical elements slowing this DWG?
    By Kevin.Sturmer in forum AutoCAD General
    Last Post: 2008-04-07, 05:54 PM
  3. Room Numbering Vertical Elements?
    By robert.manna in forum Revit Architecture - General
    Last Post: 2006-05-15, 11:34 PM
