When I touch a surface boundary with my crosshairs everything will lock up for 2 or three minutes! I only have the surface border visible. Can anyone help?
Are you attempting to draw anything or place a block?
Are your OSNAPS enabled?
does it happen in ALL Drawings?
Does it happen if you close C3D and Reopen?
I'm having the same problem - seems to be whenever my crosshairs cross a figure line. Selection preview when no command is active is de-selected and that didn't help. Any suggestions?
uncheck rollover tool tip in your options... we ran into an issue like this but with points. Also try SC or selection cycling turned off. That is in the bar with OSNAPS and ORTHO. Let us know if any of these help!
:Cheers:
Andrew Manninen
CAD Manager
The man who smiles when things go wrong has thought of someone to blame it on. - Robert Bloch
