I need to do an assembly of this type, and i can not found the way, can someone help me?, inside the attached dwg there are more specific question. Thanks in advance. (sorry for my english)![]()
You will wnt to use a CONDITIONAL sub assembly to set you assembly to handle either case depending on the conditional parameters.
I think you will wnat the Conditional Cut or Fill sub assembly for this task.
OK, after much study I now see the 'other' questions.
This assembly is deceptively complex.
There are a few approaches one can take.
One includes use of the Sub-Assembly composer; which those NOT on subscription will not be able to take advantage of.
The other will use a combination of various pieces, the Generic Pavement Section, several generic Links, as place holders and the Link Multi.
I will try to produce a coherent tutorial to illustrate.
Check back shortly as I will be posting a link here once the tutorial is posted to the
Tutorials Page on my website. This could take about an hour.
For those following, I decided against using the Link-Multi sub assembly as mentioned above for reasons that I explain in the video. Mostly due to a lack of certain flexibility that some users may or may not require.
The Tutorial is located here: http://primeservicesglobal.com/tutor...nericlinks.mp4
