Thread: MEP command panels disappeared
    2008-05
    15
    Default MEP command panels disappeared
    I'm not exacly sure what I did, but all the panel across the top of my screen have disappeared and I can't get them back. I have tried to repair the installation, re-installed the program, search the help section and have no answer. Anyone have an idea?
    ACA Community Director dkoch's Avatar
    2003-03
    Going for a long walk off a short pier
    1,847
    Default Re: MEP command panels disappeared
    I assume you are talking about the Ribbon tabs. Try typing RIBBON at the Command: prompt, and see if that brings it back.
    If that does not work, your CUI file may have been corrupted. Did you make any customizations to the CUI file? If not, you might try restoring or resetting it in the CUI editor, on the Customize tab, by right clicking on the CUI file and choosing restoring or resetting that file. Do the restore first, it will use the backup file (which should get you back to what you had just before the last change). Reset will put the CUI file back to the out-of-the-box condition, and is only available for CUI files that came with the program (so far as I know).
    David Koch
    2008-05
    15
    Restoring the CUI file didn't work but the RIBBON command did the trick! Thank You!
  1. Onscreen pulldowns while in a command have disappeared...
    By cwjean76 in forum AutoCAD General
    Last Post: 2009-06-08, 05:43 PM
  2. "Missing Curtain Panels will be replaced with System Panels to complete command."
    By ktracy.194130 in forum Revit Architecture - General
    Last Post: 2008-12-07, 08:08 AM
  3. Where are Spider Panels & Pleaded Curtain Wall Panels existed in RAC 08
    By hutch_amit in forum Revit Architecture - General
    Last Post: 2008-06-22, 08:56 AM
  4. Command Line has disappeared?
    By jbell.105232 in forum AutoCAD General
    Last Post: 2006-03-22, 12:18 PM
  5. Command Line Disappeared
    By dtbosso in forum AutoCAD LT - General
    Last Post: 2006-01-26, 10:27 AM
