Thread: Arx won't load
    2011-12
    4
    Default Arx won't load
    I can't tell if this is the same problem as posted in :
    http://forums.augi.com/showthread.php?t=97772
    I followed the advice there, but I'm still having trouble getting an arx application to load. The AutoCAD command line shows:
    Command: arx
    Enter an option [Files/Groups/Commands/CLasses/Services/Load/Unload]: L
    捡硲湅牴偹楯瑮 not found in gisducttape.arx
    AcRxDynamicLinker failed to load
    'e:\cppprojects\gisducttape\release\gisducttape.arx'
    C:\Program Files\Autodesk\AutoCAD Civil 3D 2011\acad.exe
    Out of curiosity, I loaded that response into a hex editor, and found that the mystery characters are ANSI "acrxEntryPoint".
    I compiled the arx app using Visual Studio Express 2010 - but it looks like there might be some compiler setting or such that's off - maybe? Any ideas about what could be wrong? Would it help if I posted the full generated commandline settings?
    Moderator BlackBox's Avatar
    2,391
    Default Re: Arx won't load
    Not sure but be sure you're compiling for the applicable .NET framework (3.5 for 2011), and set your processor 32-Bit/64-Bit, and I *believe* you need to reference the ARX AcDbMgd.dll, and AcMgd.dll (minimum).
    Disclaimer - I am no ARX expert.
    HTH
    "Potential has a shelf life." - Margaret Atwood
    2011-12
    4
    Well, that would explain. I was trying out Visual Studio Express 2010, and that seems to only allow .Net 4.0. On another app, I tried switching back to .Net 3.5 and got a message that .Net 3.5 only works with VS 2005.
    ...So .Net is required for C++/ARX as well as for C Sharp?
    2,391
    Visual Studio (Express or Pro) is required for AutoCAD development in all .NET languages; C++/ARX, C#, and VB.NET being the most common.
    I use Express 2010, where each of the three I mention is a separate installation, and can produce compatible compiled code (DLL) for any AutoCAD version available today in both 32-Bit, and 64-Bit machines. The main requirements are to reference the appropriate version's AcDbMgd.dll and AcDb.dll files, and to compile to the appropriate .NET framework and processor.
    This also allows for the ability to code standalone console, form, and other applications.
  1. How to load an app ?
    By nigeld in forum Revit - API
    Last Post: 2010-08-24, 02:52 AM
  2. (vl-load-com)
    By gfreddog in forum AutoLISP
    Last Post: 2008-01-04, 12:13 AM
  3. LISP load order in relationship to CUI load order
    By Steve_Bennett in forum AutoCAD CUI Menus
    Last Post: 2007-01-19, 05:43 PM
  4. (vla-load-com)
    By kennet.sjoberg in forum AutoLISP
    Last Post: 2004-09-30, 06:56 PM
