I can't tell if this is the same problem as posted in :
http://forums.augi.com/showthread.php?t=97772
I followed the advice there, but I'm still having trouble getting an arx application to load. The AutoCAD command line shows:
Out of curiosity, I loaded that response into a hex editor, and found that the mystery characters are ANSI "acrxEntryPoint".Code:Command: arx Enter an option [Files/Groups/Commands/CLasses/Services/Load/Unload]: L 捡硲湅牴偹楯瑮 not found in gisducttape.arx AcRxDynamicLinker failed to load 'e:\cppprojects\gisducttape\release\gisducttape.arx' C:\Program Files\Autodesk\AutoCAD Civil 3D 2011\acad.exe
I compiled the arx app using Visual Studio Express 2010 - but it looks like there might be some compiler setting or such that's off - maybe? Any ideas about what could be wrong? Would it help if I posted the full generated commandline settings?
