Thread: Need a Client Project Number field for title block that is project-wide
    2004-06
    Memphis TN area
    7,048
    Default Need a Client Project Number field for title block that is project-wide
    Working with an industrial client who has their own title block, and thus their own project number field. I have created the title block, and added the Project Number field along with our logo, which will contain our company's project number assigned to the project. However I need a project-wide (or type parameter field) for the client's project number so that I don't have to always type it in on every new sheet.
    I created a shared parameter for that field, loaded the sheet and parameter into the project, and created a project parameter from that field. I can set the parameter to "Sheets", but it only allows it as an instance parameter. If I try to create it as a Type parameter, Sheets is no longer available as a category. Neither is Project Info.
    Is there any way to add a project-wide parameter, or at least a sheet Type parameter, for this Client Project Number?
    All AUGI, all the time Alex Page's Avatar
    2004-03
    Wellington, New Zealand
    822
    Default Re: Need a Client Project Number field for title block that is project-wide
    You almost got it - its a mind trick!
    Add it as an instance parameter under Project Information.
    Project information only has one instance which is project wide, if that makes sense!
    2004-06
    Memphis TN area
    7,048
    ohhhh got it! I could have sworn I looked for Project Information as a category for the parameter yesterday, but in my blind fury of trying to get the thing out the door I must have missed it.
  1. 2016: Project Information Attributes in Title Block Family
    By cantcacheme in forum Revit Architecture - Families
    Last Post: 2016-09-19, 03:20 AM
  2. 2013: Title Block changes from Family to Project mode
    By a.rauen428643 in forum Revit Architecture - Families
    Last Post: 2013-10-12, 07:38 AM
  3. Title Block Project Label Information
    By mybiswas in forum Revit Architecture - Families
    Last Post: 2010-07-21, 04:54 PM
  4. Project details linked to title block
    By stevomatic in forum ACA General
    Last Post: 2006-11-30, 12:11 AM
  5. Project Number Field
    By jamie.casile80054 in forum AutoCAD Fields
    Last Post: 2006-01-06, 08:22 PM
