Thread: Display error, Wall joins
    2012-01
    2
    Default Display error, Wall joins
    Hello.
    In a workshared project with 8 floors,on one of the levels a lot of interior walls suddenly stopped joining even though they should( the blue dot is half-way over on both). This happens when I try to draw new walls in this view as well. This affects all floorplan and 3d views of this level.??? Do I have to rebuild the level and make a new central file.
    Picture of wall join is attatched. They meet like this: L
    2004-06
    Memphis TN area
    6,700
    Default Re: Display error, Wall joins
    What are your top and bottom constraints for these walls? Bottom at the floor level and top at the floor level above? Could there be walls on other phases interfering, or walls on other levels that may be slightly overlapping and interfering?
    AERC, PLLC
    Hernando, Mississippi
    2012-01
    2
    Solved.
    Copy of walls pasted into another visible workset, resulting in similar walls overlapping.
  1. Display Error when making a wall
    By jcb777 in forum Revit Architecture - General
    Last Post: 2011-12-15, 08:21 PM
  2. Wall based sweep not cutting at wall joins
    By leeba in forum Revit Architecture - General
    Last Post: 2010-07-12, 02:51 PM
  3. Wall to wall windows and corner joins
    By 3dway in forum Revit Architecture - General
    Last Post: 2008-11-25, 06:22 PM
  4. Beginner Question - Wall Joins, Wall Ends
    By jalexander.108656 in forum Revit Architecture - General
    Last Post: 2006-03-24, 06:33 PM
  5. Wall joins with differing wall heights
    Last Post: 2005-12-06, 01:51 PM
Tags for this Thread
