Has anyone come across any decent content for butt welded pipes and fittings (since Revit doesn't have any)? I really don't feel like creating my own (at this time).
Thanks in advance!
Matt
Thanks in advance!
Matt
Lucky for you, I felt like making some awhile back:
http://www.augi.com/forums/showthread.php?t=135361
Mind the lookup tables. If you don't put them in the right location, the fittings won't size correctly.
When I installed revit 2012 it came with butt weld fittings. It's under libraries/UK/Pipe/Fittings/BS EN 10253 Carbon Steel. I found they work fine for my purpose. They are however, only good for metric, but I modified my lookup tables so they work for both metric and imperial. I also double checked the sizes and everything looks good.
Thanks! I downloaded it and it's working quite well.
Just to clarify... I didn't install the UK pipes, just imperial.
Matt
