Results 1 to 7 of 7
Thread: Gambrel roofs
    I could stop if I wanted to Kroke's Avatar
    2003-04
    Redmond, OR
    446
    Default Gambrel roofs
    I'm doing a prelim with a barn style "gambrel" roof. What's the best way to do this if you've done those before?
    Thanks, first gambrel ever for me
    2003-04
    Redmond, OR
    446
    Default Re: Gambrel roofs
    I can make the roof with no problem via roof by extrusion, however, I also want to add dormers, but it won't let me edit it to cut holes in the roof I just created. So if anyone can help me/give me pointers on how to cut holes in a roof created by extrusion, please help me...
    Thank you!
    2004-06
    Besançon - France
    3,625
    Places toi dans une vue d'étage au dessus du toit
    sélectionnes le
    et utilise le bouton "Cut plan profile"
    MAintenant t upeux modifier le profil pour y faire une ouverture
    Go to on a floor plan to the top of the roof
    select it
    and uses the button "plane Cut profile"
    Now you can modify the profile to make an opening there
    Yves GRAVELIN
    Revitez !
    " Comtois, rends-toi ! Nenni ma foi ! " devise des francs-comtois
    "Y a quéqu' chos' qui cloch' là-d'dans
    J'y retourn' immédiat'ment. "
    Boris Vian
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    Even better, use the Opening tool on the Modelling Tab, select "Pick a roof to be cut by a dormer opening."
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2003-04
    Redmond, OR
    446
    Quote Originally Posted by gravelin
    select it
    I tried this method first, and it seems that I can make the void this way, but the opening takes out (it seems) a space (in plan view) from left to right, but the void goes an infinate z axis. I didn't want to cut out above a certain height. It seems it just goes up in the sky forever and I had no control over that. (Are there more controls to only let it cut to a certain elevation height?)
    So I did what Scott said (I've never had to use the opening tool yet) and it worked like a charm. Thanks for the input guys, and thanks for the tip Scott, you saved me last night on IM.
    Now I just hope they like the style of the garage/bonus room being a gambrel. I think it looks sweet and gives a huge bonus room that a regular style of roof could not have done.
    ...always learning something new in Revit ...
    2004-06
    Besançon - France
    3,625
    Kroke,
    C'est une bonne chose que tu aies pu mieux profiter de ta nuit.
    Juste une chose, je n'ai pas pu traduire Gambrel.
    peux tu me faire une petite image ?
    It is a good thing which you could better benefit from your night.
    Just a thing, I could not translate Gambrel.
    can you post me a small picture ?
    Yves GRAVELIN
    Revitez !
    Boris Vian
    2003-04
    Redmond, OR
    446
    FYI I only speak two languages: English and foul.
    Here is a gambrel roof example:
    http://www.barnplans.com/gambrelroof.html
  1. Gambrel Roof
    By harkeychad in forum Revit Architecture - General
    Last Post: 2010-01-05, 05:06 PM
  2. Roofs: Slabs, Roofs, and Trusses revisited.
    By twiceroadsfool in forum Revit Structure - General
    Last Post: 2009-10-07, 09:24 PM
  3. Gambrel Roof Fascia
    By Michael Coviello in forum Revit Architecture - General
    Last Post: 2005-05-20, 01:41 PM
  4. Roofs
    By HouseInnovator in forum Revit Architecture - General
    Last Post: 2004-03-07, 08:52 PM
