Results 1 to 8 of 8
Thread: Still no way to make linked Revit wall be room bounding?
    2004-06
    Memphis TN area
    7,048
    Default Still no way to make linked Revit wall be room bounding?
    Just want to make sure I'm not missing something. We have a large existing facility with a small renovation in one area, and then a large addition on the opposite side of the facility, which are being completed as separate bid packages. I have each building/project as separate Revit files, and have them linked together. Do I still have to place Room Bounding lines in the Addition file where the existing walls occur in the other Revit file?
    Seems odd that we can do so much with linked files - room tagging, scheduling, workset control, etc. but can't make the 3D geometry in the linked file be room bounding in the host file.
    2015-11
    151
    Default Re: Still no way to make linked Revit wall be room bounding?
    Pick the link, edit the type, and check Room Bounding. Should work.
    2015-11
    Madison, WI
    1,318
    You still might not be able to schedule certain categories within rooms from the linked model. Rooms would have to be duplicated in your host project.
    Cheers,
    Jeff S.
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Could be a Phase Setting issue as well. Make sure the Link is checked"room bounding"
    as mentioned in the other reply.
    2004-06
    Memphis TN area
    7,048
    Ah yes, I missed the Room Bounding option in the link's type properties.
    2004-06
    Memphis TN area
    7,048
    I just ran into this again on a shell/tenant fitout project, and had to search and find this thread to remember how to do it. Wonder why linked files aren't set to Room Bounding by default? Or at least have a check box available with the other options like Center/Center, Shared Coordinates, etc.
    2015-11
    Madison, WI
    1,318
    Because that would be a smart way of doing it. What I love is people forgetting what workset they're on when linking Revit files, and also remembering to pin links (either Revit, or CAD).
    Cheers,
    Jeff S.
    All AUGI, all the time Duncan Lithgow's Avatar
    2006-09
    Denmark
    621
    Quote Originally Posted by patricks View Post
    Because checking room bounding for a link adds a burden on the model, yet another thing it has to calculate... but adding the checkbox to the linking dialog might be a good idea.
  1. 2015: Linked model refuses to stay room bounding
    By jsteinhauer in forum Revit Architecture - General
    Last Post: 2017-02-03, 08:13 PM
  2. 2013: Room bounding issue in linked model phased design options
    By squidly in forum Revit Architecture - General
    Last Post: 2013-11-15, 09:18 PM
  3. Linked Files and Room Bounding
    By jhalaby in forum Revit Architecture - General
    Last Post: 2009-03-11, 04:16 PM
  4. room bounding wall
    By scz in forum Revit Architecture - General
    Last Post: 2008-06-27, 03:07 PM
  5. In place wall family/room bounding
    By gbrowne in forum Revit Architecture - General
    Last Post: 2005-10-30, 01:16 AM
