Thread: Mechanical equipment family with nested families cannot be selected as equipment for the duct system
    2008-02
    Austin, TX
    210
    Default Mechanical equipment family with nested families cannot be selected as equipment for the duct system
    I downloaded a Johnson Controls Rooftop unit (attached), and everything looks great until I try to select it as the Equipment for my duct system. I can select an out of the box VAV, but not the Johnson Controls RTU. The family uses nested families that are categorized as Mechanical Equipment, so I changed those to Generic Models, but I still can't select the unit as my equipment for the duct system. Any idea what's going on?
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    Default Re: Mechanical equipment family with nested families cannot be selected as equipment for the duct system
    Are the Connectors part of the nested families? Revit cannot connect to them if they are buried within a nested family.
    2008-02
    Austin, TX
    210
    Quote Originally Posted by CADastrophe View Post
    No the connectors are part of the parent family. I can actually connect to it just fine with ductwork, I just can't select it as the equipment for that system, so in my System Browser, only the air terminals show up for that system.
    2012-01
    813
    It's becuase the Supply Air Connector's Flow Direction is set to "In". Change it to "Out" and you can select it.
    2008-02
    Austin, TX
    210
    Bingo. Didn't even think to look at that, thanks!
  1. Circuiting Mechanical Equipment grabs non-selected elements
    By Armando Martinez in forum Revit MEP - General
    Last Post: 2016-01-20, 11:20 PM
  2. Replies: 4
    Last Post: 2012-02-15, 08:54 PM
  3. Replies: 0
    Last Post: 2011-12-09, 04:32 PM
  4. Revit duct connectors mechanical equipment
    By tim99 in forum Revit MEP - General
    Last Post: 2011-02-05, 12:57 AM
  5. Custom mechanical equipment family
    By awascher in forum Revit MEP - Families
    Last Post: 2008-09-03, 04:40 PM
