Results 1 to 1 of 1
Thread: Help, Extend Wall To Mullion
    2004-08
    39
    Default Help, Extend Wall To Mullion
    I am using Arch 2010. Please see attached pic.
    How do I get this wall to extend to the mullion in the floor plan while still cleaning up with the exterior wall in the RCP? It's apparent that it's trying to cleanup with the wall above the window.
    FYI, the shell and interior are 2 different Elements Xref'ed into the Base Plan.
    What is the work around for this?
    Thanks
    -C
  1. Cannot extend layer(s) of the highlighted vertically compound wall
    By noah in forum Revit Architecture - General
    Last Post: 2009-04-28, 06:35 PM
  2. Continuous footings - extend beyond end of wall?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2006-01-10, 11:23 PM
  3. Cannot extend layer(s) of the highlighted vertically compound wall.
    Last Post: 2005-12-13, 08:29 PM
  4. Can't extend wall layers vertically
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2005-07-05, 09:10 PM
  5. Make a finish extend beyond the logical top/bottom of a wall
    By Wes Macaulay in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-04-26, 05:53 PM
