Thread: help required with modeling void form cone
    2011-12
    9
    Default help required with modeling void form cone
    Hope some one could kindly offer me some help, attached is a common cuboid,
    I made a void cone with the vertex along one of the edge of the cuboid aimed to cut the cuboid.
    but the problem is, if the vertex angle is very sharp, it will inform me that Revit Can't keep elements joined.
    then I can't cut.
    but if I sslightly move away the cone from the edge, everything works fine.even inside the cuboid.
    and If the vertex angle is larger or say with lower slope, it also works.
    20120201 19 5.png is the offset one ,
    20120201 20 11.png is the one with larger vertex angle,
    these two both works well
    20120201 20 9.png is the one with very sharp vertex angle I have problem with
    bug1Family1.rfa is model which I have problem with.
    I could stop if I wanted to CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    386
    Default Re: help required with modeling void form cone
    Try adjusting the profile of the void so that it doesn't have such sharp angles, as per the attached image.
    2011-12
    9
    Quote Originally Posted by CADastrophe View Post
    Thank you,
    yet I wanna know the cause of this problem, some system limitation or so.
    It's really hard to predict the result in revit mass.
    2006-03
    London, UK
    810
    Quote Originally Posted by ikonome602218 View Post
    Thank you,
    Revit doesn't like lines that end/meet right on a tangent. No idea why - I reckon a zero gets into the calculations where it shouldn't be.
    Anyway, when carving or joining, try not to have the join line at the end of a curve, where the other piece meets it at an exact tangent. Extend one piece beyond the other, to give some 'overlap'
    2011-12
    9
    Quote Originally Posted by tomnewsom View Post
    thanks, I will follow your suggestion
  1. generic model , void form, void extrusion
    By ntnik in forum Revit Architecture - General
    Last Post: 2009-01-29, 12:59 PM
  2. Void Form for Coffered Ceiling/Slabs
    By r.grandmaison in forum Revit Architecture - Families
    Last Post: 2008-09-12, 04:45 AM
  3. Void form can't cut the wall
    By alext in forum Revit Architecture - Families
    Last Post: 2006-02-25, 04:29 PM
  4. Complex form modeling help?
    By tbarnesarc in forum Revit Architecture - General
    Last Post: 2005-06-29, 04:35 AM
  5. Cut Geometry, Solid form, Void form
    By mmolina in forum Revit Architecture - General
    Last Post: 2005-05-11, 09:33 PM
