Thread: DYN doesn't work
    2012-02
    Default DYN doesn't work
    I'm just starting out w/ cad so humor me if this is a stupid question. I'm running 2009 LT on a Win7 machine. Everything seems to be working as advertised but while drawing a rectangle I found that it doesn't matter if the DYN button is on or off, when I make my 2nd point, it shows up as if it is calculated from the origin, not the last point. I'm following the first exercise in a book step for step, but can't get this function to work. Any ideas??
    0,0,0 The Origin
    8,026
    Default Re: DYN doesn't work
    Hi, welcome to AGI.
    Have you tried "@" before the second point? It's use varies in newer versions but was mandatory in earlier versions.
    Rectangle
    20,20
    @20,20
    should give a square from 20,20 to 40,40.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
  1. DB insert doesn't work...
    By randyspear in forum Dynamic Blocks - Technical
    Last Post: 2009-10-09, 01:21 PM
  2. YES or NO to all doesn't work???
    By csmac2004 in forum Productstream - General
    Last Post: 2009-03-03, 05:31 PM
  3. Specify New Work Plane - doesn't work?
    By bnelson.188587 in forum Revit Architecture - General
    Last Post: 2008-07-24, 04:50 PM
  4. Right-Click doesn't work
    By msretenovic in forum AutoCAD General
    Last Post: 2007-12-03, 05:30 PM
  5. Just in case 8.0 doesn't work???
    By rookwood in forum Revit Architecture - General
    Last Post: 2005-04-27, 08:11 AM
