Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: AutoCad 2000 LT leader issue
  1. #11
    2011-12
    22
    Default Re: AutoCad 2000 LT leader issue
    I'll try that later on today when I get a chance.
  2. #12
    2011-12
    22
    Did a REGEN after a copy/paste-leader went somewhere issue....did not change the stray leader. I did check the coordinates and the tail end X/Y on the stray matched the tail end X/Y on the original.
  3. #13
    100 Club pendean's Avatar
    2001-12
    Dallas, TX
    171
    Post a DWG file with the issue, put notes inside on how we can replicate your issue and let's all have a real look at what you are doing. I suspect because you are using an ancient tool in an ancient version of AutoCAD, everyone here forgot it's inner workings enough to not be able to help figure out the issue.
    Dean Saadallah
    http://LTisACAD.blogspot.com
  4. #14
    0,0,0 The Origin
    8,024
    Quote Originally Posted by concretelackey View Post
    If you mean that the values at the correct location and at the wrong location are the same then there is definitely a serious problem.
    1, do as Dean says (above).
    2, do a complete reinstall of acad.
    3, get details of display hardware and driver.
    4, get a more capable computer.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
  5. #15
    2011-12
    22
    I'll post a noted file as soon as I can.
    I have noticed that by using Leader from the Dimension menu does not cause stray lines, only if I QLEADER from the Dimension toolbar.
  6. #16
    2011-12
    22
    I just tried copy and paste on several drawings and all transferred fine.
    I may have discovered the issues involved.
    Earlier this week I had met with an engineer for project review and stamp. He suggested that I limit the use of arial text in my drawings. He felt that arial is a RAM hog and recommended using simplex text instead. Since then I have converted a vast majority of my blank masters to simplex.
    I do reliaze that the computer that I am working on is "slightly" under powered, I'm still being the squeaky hinge with my boss on that issue.
    I'll keep you posted if the problem pops up again..
    thanks for the input!
  7. #17
    0,0,0 The Origin
    8,024
    If you would like slightly better looking text with little extra ram overhead use RomanS - for all text.
    John B
  1. 2010: Leader Issue
    By Dr._House in forum AMEP General
    Last Post: 2011-09-07, 08:26 PM
  2. Replies: 6
    Last Post: 2009-06-01, 07:10 AM
  3. Leader Issue
    By mlf in forum AutoCAD General
    Last Post: 2009-02-27, 08:06 PM
  4. Leader Plotting Issue
    By jaroguy in forum ACA General
    Last Post: 2007-10-15, 05:38 PM
  5. AutoCAD 2006 Text Editor, restore to AutoCAD 2000 behaviour
    By louis.64641 in forum AutoCAD General
    Last Post: 2007-05-29, 03:58 PM
