I'm having an issue with an electrical link file not associating with the workset it says it is associated with. Or more accurately, it's associating with TWO worksets.
We have a MEP central file that has the electrical file linked in. When you click on the electrical file inside the MEP file it says that it's on the workset LINK_Revit_Elec. Which is the correct workset we setup for the electrical link.
BUT, if I close the workset named "Hydronic", which I often do when working on ductwork for this project, the electrical file disappears. If I close the LINK_Revit_Elec, the link also disappears.
Why is the link associating with two different worksets and how do I fix it? The hydronic workset is quite large and not opening it helps with load times.
