Results 1 to 7 of 7
Thread: Stretch Equally 2 sides
    2005-01
    119
    0 Did you find this post helpful? Yes
    Default Stretch Equally 2 sides
    Heres a block I started, I want it to stretch equally both way, placing the nails 2 1/16" apart and maintaining a nail at the center point, I tried just placing 3 nails in the center and arraying, but I'm missing something
    Mac
    Active Member sandrews.253556's Avatar
    2010-06
    91
    Default Re: Stretch Equally 2 sides
    Hmmm…I tried several ways to get this to work like you requested. This way seems to do the trick (see attached.) Take a look at how I constructed it and come back if you have questions.
    2005-01
    119
    I like it! It's the way I tried to build it, but I must have had wrong selection sets or a wrong sequence somewhere, so I scrapped it after several tries, VERY nice, 1 question
    I actually want the nails to be 2 1/16" apart, I tried to adjust the rows to this factor but I get unexpected results, any ideas? what's the trick?
    Thanks very much
    striving to be a better dynamic block builder
    Mac
    All AUGI, all the time clshade's Avatar
    2009-01
    B5
    544
    Column Offset for the Array needs to be 2-1/16" for the spacing.
    Also - The posted block has the fastener shape copied over itself. This must be done since an entity can only be tied to one Array Action.
    One fastener for the Array on the left and one fastener for the Array on the right. Tricky
    Charles Shade AutoCAD LT 2014, Dynamic Blocks
    www.cshadedesign.com
    2010-06
    91
    Sorry about that. I realized after posting that I used the wrong dimension. You can change it by going into the block editor, highlighting an array action, and then going to properties and modifying the column offset to the correct dimension. Remember to repeat it for both array actions.
    2005-01
    119
    hmmm, I changed the value for the rows to 2 1/16" and It does not work, I think the problem is related to the the stretch action being shorter, but can't figure it out just yet, what do you think?
    Mac
    2009-01
    B5
    544
    When changed here there was no problem with the Array spacing working as intended.
    Post your changed block - all else is conjecture
  1. Stretch box on both sides equally
    By vtmiii in forum Dynamic Blocks - Technical
    Last Post: 2012-11-26, 06:43 PM
  2. All Families Are NOT Created Equally
    By seandburke in forum Revit Architecture - Families
    Last Post: 2009-12-15, 01:10 AM
  3. Array from center equally two directions
    By jnoon in forum Dynamic Blocks - Technical
    Last Post: 2009-09-08, 12:12 PM
  4. Equally dividing mullions
    By pligkid20 in forum Revit Architecture - General
    Last Post: 2008-03-01, 03:14 PM
  5. Trying to Stretch a hatch in a Dynamic Block with the Stretch parameter
    By hnewman in forum Dynamic Blocks - Technical
    Last Post: 2007-11-05, 09:34 PM
