I'm going to try to do this without screen shots, here goes:
I have a text note that I have loaded into the project off my server. And by text note I mean symbol. This text note is essentially a revit family with a label (A) and a box around it. Included in this is are three tertiary labels known as Text*, Sheet and Sheet.
I load this into an ongoing project and "Do you wish to override" popup window does NOT appear as expected. It continues to load the label text in the box as 4 (instead of A) and in the properties window it defaults to "Align window to surface...etc..." It is not alphabetical since a note described as A appears before "Align window to surface....etc.." It should be defaulting to Text*, right?
What do I need to do to make the default read as Text* (see above) instead of defaulting in the project to "Align window to surface adjacent...etc.."?
What am I trying to achieve? I just want my Symbol Note back to normal. It is tied to too many things in the project to just go and delete it out of the Family:Generic Annotations: + SHA_symbol_Text*
Things I have tried:
Editing the family and overriding the properties, reloading it - (no effect)
Editing where the default template reads from (C:\ to N:\(server))
Changing the last known insert parameters of the symbol text
-rbc
