Results 1 to 10 of 14
Thread: Contour elevation labelling..........help
    2011-10
    40
    Wink Contour elevation labelling..........help
    hello all,
    i wrote below piece of code for labelling elevation to contour(Polyline). it works but it labels at end of contour. what i want is to label in middle of contour with proper aligning text label . can anybody modified it for me..?
    (defun c:qq()
    (setq ss (ssget'((0 . "LWPOLYLINE"))))
    (setq sslngth (sslength ss))
    (Setq idx 0)
    (repeat sslngth
      (setq ename (ssname ss (setq sslngth (1- sslngth))))
       (setq edata (entget ename))
       (setq xy (cdr (Assoc 38 edata)))
       (setq xy1(cdr (Assoc 10 edata)))
      (setq xx(rtos xy 2 0))
      (command "text" xy1 10 30 xx "")
    sample dwg attached ..........!
    2002-08
    101
    Default Re: Contour elevation labelling..........help
    Hello,
    You can use also the dynamic fields !
    (vl-load-com)
    (defun c:Label_Side_Elevation ( / js htx AcDoc Space nw_style n obj ename pr pt deriv rtx nw_obj)
    	(princ "\nSelect polylines: ")
    	(setq js
    		(ssget
    			(list
    				'(0 . "LWPOLYLINE")
    				(cons 67 (if (eq (getvar "CVPORT") 1) 1 0))
    				(cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model"))
    	(cond
    		(js
    			(initget 6)
    			(setq htx (getdist (getvar "VIEWCTR") (strcat "\nSpecify text height <" (rtos (getvar "TEXTSIZE")) ">: ")))
    			(if htx (setvar "TEXTSIZE" htx))
    			(setq
    				AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
    				Space
    				(if (= 1 (getvar "CVPORT"))
    					(vla-get-PaperSpace AcDoc)
    					(vla-get-ModelSpace AcDoc)
    			(cond
    				((null (tblsearch "LAYER" "Label Elevation"))
    					(vlax-put (vla-add (vla-get-layers AcDoc) "Label Elevation") 'color 96)
    			(cond
    				((null (tblsearch "STYLE" "Romand-Label"))
    					(setq nw_style (vla-add (vla-get-textstyles AcDoc) "Romand-Label"))
    					(mapcar
    						'(lambda (pr val)
    							(vlax-put nw_style pr val)
    						(list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag)
    						(list "romand.shx" 0.0 (/ (* 15.0 pi) 180) 1.0 0.0)
    			(repeat (setq n (sslength js))
    				(setq
    					obj (ssname js (setq n (1- n)))
    					ename (vlax-ename->vla-object obj)
    					pt (vlax-curve-GetpointAtParam ename (setq pr (* 0.5 (vlax-curve-getEndParam ename))))
    					deriv (vlax-curve-getFirstDeriv ename pr)
    					rtx (- (atan (cadr deriv) (car deriv)) (angle '(0 0 0) (getvar "UCSXDIR")))
    				(if (or (> rtx (* pi 0.5)) (< rtx (- (* pi 0.5)))) (setq rtx (+ rtx pi)))
    				(setq nw_obj
    					(vla-addMtext Space
    						(vlax-3d-point (setq pt (polar pt (+ rtx (* pi 0.5)) (getvar "TEXTSIZE"))))
    						0.0
    						(strcat
    							"%<\\AcObjProp Object(%<\\_ObjId "
    							(itoa (vla-get-ObjectID (vlax-ename->vla-object obj)))
    							">%).Elevation \\f \"%lu2%pr0\">%"
    				(mapcar
    					'(lambda (pr val)
    						(vlax-put nw_obj pr val)
    					(list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation)
    					(list 5 (getvar "TEXTSIZE") 5 pt "Romand-Label" "Label Elevation" rtx)
    	(prin1)
    2011-10
    40
    ya, it works great ! but it highlights that value in closed filled color. that what i dont want..only value with Arial font.
    and one more think if you know anyother alternatives to do the same. let me know plzz..
    Quote Originally Posted by Bruno.Valsecchi View Post
    Hello,
    (vl-load-com)
        (setq js
            (ssget
                (list
                    '(0 . "LWPOLYLINE")
        (cond
            (js
                (initget 6)
                (setq
                    Space
                (cond
                (cond
                        (mapcar
                            '(lambda (pr val)
                    (setq
                    (setq nw_obj
                        (vla-addMtext Space
                            0.0
                            (strcat
                    (mapcar
                        '(lambda (pr val)
        (prin1)
    2001-03
    Tallahassee, FL
    1,096
    Try ContourAnnotate.lsp. It works on your attached drawing or any Map data or polylines with elevations. It places the text right-side up even in twisted views. It uses the current Text Style and Size and places the text on the same layer as the contour so it turns off with the layer. Give it a try.
    Tom Beauford P.S.M. - Civil 2013 on Windows 7 Pro
    Design Analysis - Leon County Public Works/Engineering
    Ph# (850)606-1516
    2004-08
    Hartford, Michigan
    3,086
    Quote Originally Posted by sanrajbhar677632 View Post
    what if you set FIELDDISPLAY to 0?
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2002-08
    101
    Two way possible, define a new style with arial or force in Mtext the style with the good font
    Same answer that ccowgill FIELDDISPLAY
    With font forced in Mtext
    (vl-load-com)
    (defun c:Label_Side_Elevation ( / js htx AcDoc Space n obj ename pr pt deriv rtx nw_obj)
      (setq js
        (ssget
          (list
            '(0 . "LWPOLYLINE")
      (cond
        (js
          (initget 6)
          (setq
            Space
          (cond
            (setq
              pt (vlax-curve-GetpointAtParam ename pr)
            (setq nw_obj
              (vla-addMtext Space
                0.0
                (strcat
                  "{\\fArial|b0|i0|c0|p34;"
            (mapcar
              '(lambda (pr val)
              (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation 'BackgroundFill)
              (list 5 (getvar "TEXTSIZE") 5 pt "Standard" "Label Elevation" rtx 0)
      (prin1)
    2001-12
    54
    gave it a try.... don't work.. bunch of stuff in the program that is or is not needed for simple contour labeling.
    i.e. load tcasesup.lsp ??????
    Steve
    2002-08
    101
    For Object Data, i make this if you want try.
    I know bug with tag OD if special character
    2001-03
    Tallahassee, FL
    1,096
    Quote Originally Posted by steveo View Post
    Steve
    Sorry, try adding
     (vl-load-com)
    to the start of the routine. It's required to be loaded for using any visual lisp. Most who use it a lot have it loaded automaticly. I don't add it to my routines. There is extra labeling stuff in there. I forget sometimes that not everyone installs the free Express Tools that come with AutoCAD. If you don't have it just remark it out, it's not used for the contour elevations anyway. I use the Express Tool tcase for labeling things like street names which in our GIS are all capitalized.
    Ph# (850)606-1516
    2001-12
    54
    Sorry, try adding
     (vl-load-com)
    Tom... now I get the following error...
    Select point on Contour Line or Street Segment:
    Error: no function definition: ADE_ODGETTABLES
    vl-load-com added ok and I have express tools ok in Acad2008 thanks for reply.
    Steve
  1. Help With Contour Labeling Elevation Precision
    By aspencer.226869 in forum AutoCAD Civil 3D - General
    Last Post: 2010-08-13, 09:26 PM
  2. Contour labels all reading the same elevation?
    Last Post: 2008-03-18, 05:43 PM
  3. Looking for GIS elevation contour data.
    By bmonk in forum AutoCAD Map 3D - General
    Last Post: 2007-07-20, 12:14 PM
  4. Labelling contour lines and spot elevations in AutoCAD 2007
    By bh.mccarthy in forum AutoCAD General
    Last Post: 2007-04-11, 03:58 PM
