Thread: Missing MEP 2012 Ribbon Icons
    2011-12
    4
    Default Missing MEP 2012 Ribbon Icons
    Hi,
    I'm creating an enterprise cuix, but when ever I transfer over ribbon items from the stock MEP.cuix into my enterprise.cuix, all the MEP based command Icons are missing are are replaced by question marks.
    I located the mep.dll and placed it in the same folder as the enterprise cuix, and also tried renaming it to match the enterprise.cuix name, but that still did not work....
    Any suggestions?
    Thanks Much,
    Marcus
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,665
    Default Re: Missing MEP 2012 Ribbon Icons
    A cuix like MEP.cuix will look for icons in a same name dll file like mep.dll, there is no way to set your.cuix to look in mep.dll for icons, though you can copy mep.dll to your.dll although I wouldn't recomend it. Are you just interested in the icons or are you adding the MEP commands? Is it a company version of MEP.cuix?
    2011-12
    4
    It is for a company version to be set as the enterprise CUIX file. We would like to develop our own ribbon using the items found in the stock interface but just arranged differently. If I could do it without modifying the default one (i.e. transfer/copy items from the stock mep.cuix to the comapny cuix and then make it a partial to the mep.CUIX which would be main enterprise interface file) then I would not need to rebuild the company's ribbon interface with every future upgrade.
    At least that was the intention... to get around this, I've been just modifying the deafult mep.cuix... If the mep tools exist in any other file, the tool icon seem to get lost... but it would be nice if I could resolve it! I know there has got to be a way...
    2009-11
    5,719
    Is the desired level of customization not possible through a customized WORKSPACE?
    Consider using MEP.CUIx as your Main CUIx, then create your Enterprise CUIx from an empty CUIx, only containing items specific to your company (don't duplicate, or copy over any stock items). Then configure the desired workspace from Enterprise CUIx, which will properly reference all CUIx components without the need for all of the added work on your part. Just saying.
    HTH
    Computer Specs:
    2009-11
    5,719
    Also FWIW, here's a shameless plug for an Autodesk University course I found helpful when learning to manage CUI(x) for our deployments (direct link to PDF):
    A Working Enterprise CUI In Front of Your Eyes
    Computer Specs:
  1. AutoCAD 2012 ribbon has icons but no text
    By michael.12445 in forum AutoCAD General
    Last Post: 2012-03-06, 04:24 PM
  2. 2012: C# - Ribbon Icons
    By Bryan Thatcher in forum Revit - API
    Last Post: 2011-08-29, 06:19 AM
  3. MEP 2011 - Missing icons in Ribbon from Enterprise CUI
    By ModelBoss in forum AutoCAD CUI Menus
    Last Post: 2010-09-07, 12:07 PM
  4. icons missing on ribbon tab
    By yonlih in forum AutoCAD Mechanical - General
    Last Post: 2010-08-03, 02:51 AM
  5. Ribbon Icons
    By bshank.140587 in forum ACA General
    Last Post: 2010-03-23, 11:33 AM
Tags for this Thread
